PTT via Pluto GPO pins
Also known as ADALM-PLUTO.
M0TGC
Re: PTT via Pluto GPO pins
#11
Unread post by M0TGC »
GPIO config not found, see screen
David M0TGC
#12
Ah,
Will check this.
Rob O
#13
Unread post by Rob O »
(Switched to forum as suggested)
As discussed in https://sdr-radio.groups.io/g/main/message/61015, using this relay board is exactly what I want to do as well. I do not want to add another computer/usb dependency to the radio setup by using a USB relay, if it can be avoided.
Have you thought whether you will be tackling this issue?
73,
Rob, M5RAO
dg9bfc_sigi
#14
Unread post by dg9bfc_sigi »
install fw from evariste ... that switches ptt relay
using it here now for several months and it just works
dg9bfc sigi
