PTT via Pluto GPO pins
Re: PTT via Pluto GPO pins
Ah,
Will check this.
Will check this.
(Switched to forum as suggested)
As discussed in https://sdr-radio.groups.io/g/main/message/61015, using this relay board is exactly what I want to do as well. I do not want to add another computer/usb dependency to the radio setup by using a USB relay, if it can be avoided.
Have you thought whether you will be tackling this issue?
73,
Rob, M5RAO
73,
Rob, M5RAO
install fw from evariste ... that switches ptt relay
using it here now for several months and it just works
dg9bfc sigi
dg9bfc sigi
