You are now in the test team.Dean wrote: ↑Mon Dec 07, 2020 3:43 pm Is there a particular gateware version we should be using with the Lime USB and Console version 3.0.25?
I picked up that laptop I mentioned in the "computer talk" area and I'm trying to work through an issue. When I select the Lime more times than not I get no FFT, no sound etc.. I have stop it, then restart. Sometimes I closeout the program and restart again. This might take a number of attempts before things start working.
In the past I was part of the test group on groups.io. but no longer have access to the test builds so I don't know if this is something that .26 might fix.
BTW when it does work I can use any bandwidth available. The new laptop is going to be a winner when I get this stuff squared away.
New Lime Suite 20.10 release
Re: New Lime Suite 20.10 release
Thank you. I will give it a go later today.
