WebSDR as RX and SDR Console as TX?
HB9HCI
Unread post by HB9HCI »
When receiving QO-100, problems with frequency stability quickly arise. Therefore it would be ideal if one could integrate a WebSDR like https://eshail.batc.org.uk/nb/ receiver into the SDR Console.
My attempt to use a Python program to read the SDR Console TX frequency and transfer it into the WebSDR failed because I could not get the TX frequency from the SDR Console. Is there any way to read this TX-Frequency from outside the SDR Console?
yo7fws
Re: WebSDR as RX and SDR Console as TX?
Unread post by yo7fws »
Hello
I think a solution would be a program that emulates the CAT operation of a transceiver.
Extract the frequency from that emulator and use it further.
Constantin
HB9HCI
Hello Constanin
good idea. I didn't found/expect the CAT ability of SDR Console. With a virtual com driver it should work....
Thanks Andreas
In case you can't find it Andreas.
For Simon: the yellow circeled statement has proberbly been outdated...there's a tool for Omni-Rig somewhere on the net that's called Omni-Rig Sync to sync two rigs via a VSC.
