Since upgrading to version 3.026, I can no longer open Icon Select Radio.
When I open it, the sdr consol window freezes.
It is impossible to do anything. I can no longer select any radio station. Both locally and network...
Locally the sdr is RSPDUO
Only the versions under and 3.0.25 works.
Can someone help me?
Many Thank's
Merci beaucoup
Screen freezes since version 3.0.26 and 3.0.27
Re: Screen freezes since version 3.0.26 and 3.0.27
I suppose you can't send a logfile as SDRC hangs, or can you?
If you can't then i advice to go back to 3.0.25, delete all radio's in "Select Radio", re-install 3.0.26 or 3.0.27 again and add the radio again.
Pls let us know if that helped ok?
I suspect your solution will work, Leon. I think definitions changed a little about .25 to .26 transition for some types of front ends.
