James,
Thanks - sadly you don't have enough resources to run the program . You're the first person who's reported this, I have a very aged Core2DUO 2GHz laptop with Windows 7 which is ok.
Time for a new PC maybe?
Program will not run
Re: Program will not run
Thanks Simon. I also noticed in the last screen capture I sent you, the error is referencing a file on E:\
I don't have any drive on E:
Thoughts?
James
Thoughts?
James
No thoughts, not relevant, sorry.
Okies. Thank you so much for your time with this, I appreciate it. Once I upgrade the 'shack' PC, I will install it again.
Cheers,
James
VA3JPX
Cheers,
James
VA3JPX
James,James_VA3JPX wrote: ↑Sat Mar 12, 2022 3:06 pm Okies. Thank you so much for your time with this, I appreciate it. Once I upgrade the 'shack' PC, I will install it again.
Cheers,
James
VA3JPX
Try this kit...
Hi Simon, this kit is working. I have a map. Thanks for all your efforts!
James
James
