Hello All,
I'm trying to install my Pluto with SDR console V3 onto my new PC.
When I start up the SDRconsole, the prog go to Radio Definitions, my pluto is plugged in my pc with USB, but when I do a search the pluto is not found.
When I add the pluto manually it shows up with adress ip strandard (192.168.2.1). I cannot acces the pluto via this ip ?
Help welcome.
Best 73 Rudi - ON7CL
PS: On my laptop with Windows 10 Home, all is working.
New PC Windows 10 (64bit) + SDR Console + PLUTO
Re: New PC Windows 10 (64bit) + SDR Console + PLUTO
If the Pluto is not found then check your USB cable, make sure it's in the correct USB connector (there are two).
Tnx, all running ![Smile :)](./images/smilies/icon_e_smile.gif)
