Page 1 of 2
SDR Console v3 Install Footprint?
Posted: Fri Apr 09, 2021 4:13 pm
by Bo3b
New LAN-IQ Owner searching for SDR control software - SDR Console v3 appears to work and is promising. However install footprint seems huge (600+ Mb?) - Any way to determine minimum disk space & files needed for a single radio?
Thanks.
Re: SDR Console v3 Install Footprint?
Posted: Fri Apr 09, 2021 4:24 pm
by G0OFE
Yes, just about 600mb here. You won't need much more for a single or even multiple radios, unless you're making IQ recordings. I put those on a separate disk anyway. My user files take a few mb.. includes all my radio and favourites definitions.
Posted: Fri Apr 09, 2021 4:47 pm
Just install the whole lot. Disk is cheap these days, the reason for the size is the number of radios supported and other supporting data files such as the geo database.
Posted: Wed Apr 14, 2021 12:12 pm
by Bo3b
Thanks for the reply. Running on older laptop, software appears to run OK but disk space is limited. Any way to identify the radio support, data files and delete? How much disk space recover can be expected for a single radio leaned down install? (Maybe allow selection during install?)
Posted: Wed Apr 14, 2021 12:29 pm
Bo3b wrote: ↑Wed Apr 14, 2021 12:12 pm
Sorry, I really don't have time to do this.
Consider a bigger drive for the laptop, it's actually quite easy to replace a drive and keep your current Windows installation.
Posted: Wed Apr 14, 2021 2:27 pm
by Bo3b
Thanks. Hardware upgrade to laptop is not an option and the idea of software change to allow radio selection on install was just a suggestion. Question was which files are unnecessary, and can be deleted, for a single radio use - In this case the LAN-IQ? If there is no easy definitive answer, will try to determine via experimentation but must be some guidelines and idea of minimum size?
Posted: Wed Apr 14, 2021 3:22 pm
Bo3b wrote: ↑Wed Apr 14, 2021 2:27 pm
Disk upgrades are easy, very easy.
Posted: Wed Apr 14, 2021 3:55 pm
by Bo3b
Even if very, very, VERY easy AND cheap or free, hardware upgrade not an option. Sorry! Will experiment and probably break software things for more frustration but appears to be only option. Would think others also concerned for SDR Console footprint and better answer...
Posted: Wed Apr 14, 2021 5:27 pm
Bo3b wrote: ↑Wed Apr 14, 2021 3:55 pm
Attach an external disk and install there.
Posted: Wed Apr 14, 2021 7:50 pm
by Bo3b
Thanks for the suggestion but additional hardware expense doesn't seem like appropriate solution. Should be some software overhead that can be trimmed to create a smaller footprint for those interested in leaner install. Will experiment with file deletion guesses to determine what, if anything, can be discovered the hard way to solve issue...
