AM reception problem
Posted: Fri Apr 09, 2021 7:37 pm
Having problems with AM & SSB reception with an RSP-1a whenever I reduce the RF gain below 6: very distorted or no audio. It sounds just like a biasing problem with an op amp when the DC bias point shifts toward one of the supply rails. Everything looks normal to me in the screen shot. I have the same problem with the RX-888, though kind of backwards: if I set the HF attn. to -20 dB reception is OK, at -10 it's very distorted & at 0 the audio fades away after a couple seconds of severe distortion. The RSP-1a works perfectly in SDRuno at all RF/IF gain combos. The problem is in the MW band I have to turn the RF gain in SDRC way down to avoid overload, & at those RF gains the demoded audio goes away.
Also attaching a short video that shows what happens as the RF gain is changed.
Bob NO6B
Bob NO6B
