Data Analyser - consecutive projects
Posted: Wed Apr 14, 2021 1:25 pm
Data Analyser works perfectly on the 1st analysis of each session. But moving on to a new project results in an image which appears “noisy” and overlaid with hash. In order to get a clear image it’s necessary to close the Analyser window and re-open it from the main SDRC window.
The sequence of attached screenshots show 3 successive analyses (in order 1 to 3) without closing the window in between. I just used the tuning button to step up 9kHz from 846 and in the 3rd to step back to 846kHz. Note the difference between 1 and 3 which are both 846kHz.
No settings were changed between runs. Attachment 4 shows the settings in use.
The attachments have loaded 4 to 1 instead of the intended 1 to 4!!
