Saving Settings etc
Posted: Tue Apr 20, 2021 7:31 pm
I was exploring some of the neat changes that can be made via options and was delighted I could tweak many to my liking to make my RSPdx play even better. But when I closed console down and restarted it some stayed but many went back to default. Is there a way to save all of them? I am using a WIN10 laptop.
1. I would like to save the "shaded" portion of the signal in the pan display window. Right now I select it but when restarted it is not shaded in.
2. Save the number of "peaks" I select. I usually pick "1" and like to see the SNR for it but when restarted it goes back to zero.
3. While talking about the "peaks" setting, which is awesome, I really like that I can select the peak to display SNR. I set peaks to 1 and observe the SNR of the station I am tuned to. The problem is if a stronger station appears any place on the screen the SNR data jumps over to the stronger station and not my tuned frequency. Is there any way to force the SNR read out to stay on my tuned frequency? I do not want to have to zoom WAY in so that my station or tuned frequency is the only signal seen in the pan display.
4. I like to use a resolution display of X2 but when restarted it goes back to default.
5. The frequency and span box which I like enabled disappears when I restart the program.
6. Also I cannot keep my tuned, center frequency to stay in the middle of the pan display. I have enabled the keep centered option but it does not seem to make any difference.
