Help with Auto Mute if used as Panadapter needet...
Posted: Tue May 18, 2021 9:12 am
by DO1ATM
Dear Sirs,
Im using a RTL Stick and Omnirig as Panadapter on my FT-950 an it works very well.
Usulay the computer audio is turend off and I'm working only with the Waterfall BUT sometimes I like to use the Computer Audio special for weaker Signals.
But when im sending I hear myselve over SDRConsole and this is annoing.
I tryed to configure Auto-Mute over the Tool Tab but had no luck with this.
Can anyone help me out ??
thank you
tom[/font]
Re: Help with Auto Mute if used as Panadapter needet...
Posted: Tue May 18, 2021 7:15 pm
Hi, did you tried to disable TX monitor? (see red circle)
73, Leon
Posted: Wed May 19, 2021 3:11 pm
by DO1ATM
Thank you for answering. Unfortunately the whole Transmit section is grey and not accessible.
I thoght this is for sending with eg. HACKRF or so ?!
How can I get this accessible ?
73 tom
Posted: Wed May 19, 2021 6:18 pm
Sorry Tom, TX cannot be enabled with a RTL stick ofcource. Should have read better, my bad.
I think there's no way to tell SDRC it has to mute when you are transmitting with an external TX but there are hardware solutions like this one:
https://nl.aliexpress.com/item/1005001392348124.html
Posted: Wed May 19, 2021 8:55 pm
by m3ghe
PD3LK wrote: ↑Wed May 19, 2021 6:18 pm
No Tom that isn't what he needs. That item is to allow you to share the antenna between your transceiver on TX and your SDR on RX.
All he needs is a method to mute the PC loudspeaker when transmitting and there is various simple ways of doing this.
A relay controlled by the PTT line of the TXCVR disconnecting the PC speaker/headphones is the easiest to construct. A little more complex is a RF switch to do the same thing.
I'll see if I can find a production solution.
Posted: Wed May 19, 2021 9:15 pm
by m3ghe
One question are you using the RTL SDR connected to the IF output or to the antenna?
Posted: Thu May 20, 2021 10:21 am
by DO1ATM
@Leon: Thank you, but I think Martin got it.
@Martin: I think you got it *g*. Yes, I'm using the internal IF for the RTL Stick. I hoped there was a way in the Software to Mute the Audio while sending. So, as you describe, I think I have to grad the RS242 signal with an Arduino and cut the IF input for the Stick While sending. Seems to be not too difficult to do..
Posted: Thu May 20, 2021 10:42 am
I wonder if he has tried "home->options->AutoMute. Check the checkbox and set the muting levels. This only works if the signal when TXing is maybe 10 dB larger than incoming signals as a minimum.
Posted: Thu May 20, 2021 11:06 am
by DO1ATM
jdow wrote: ↑Thu May 20, 2021 10:42 am
Thank you,
but as you can see in the initial post ... Yes. But it did'nt work as in the Screenshot (wrong Parameters maybe ?).
Posted: Thu May 20, 2021 11:11 am
by DO1ATM
m3ghe wrote: ↑Wed May 19, 2021 9:15 pm
The Stick is connected via IF output.
I think I can take the RS232 Signal, read it with a Arduino an switch a Realis if there is no posibillity in the Software ..
