SDR Console V2.3 Build 3825 Radio Definition Issue
youngb
Unread post by youngb »
The SDR I am currently using is the BladeRF Small Rev. 2 (x40). I'm very new to SDR's, therefore I apologize for my lack of knowledge if I'm doing something wrong. When I try to select "BladeRF" in the radio definitions the SDR Console returns back "nothing found, sorry". Could anyone shed some light on this problem? I've looked at other posts regarding this issue but was unsuccessful. Thank you.
EDIT: I installed the newest version of SDR Console and am still experiencing the same issue.
bladeRF-cli version: 1.8.0
libbladeRF version: 2.4.0
Firmware version: 2.4.0-git-a3d5c55f
FPGA version: 0.5.0 (configured from SPI flash)
Board: Nuand bladeRF (bladerf1)
Serial #: c7cff2d11e720d5e9534a232c56d077c
VCTCXO DAC calibration: 0x8e58
FPGA size: 40 KLE
FPGA loaded: yes
Flash size: 32 Mbit
USB bus: 1
USB address: 42
USB speed: SuperSpeed
Backend: libusb
Instance: 0
Here is the logfile from the SDR Console:
10:30:15> Instance
10:30:15> This is the only instance ......: Yes
10:30:15> Single instance mutex created ..: Yes
10:30:15> Single instance mutex handle ...: 0000029C
10:30:15> Single instance mutex class ....: SDR-Radio-Console-App-0-0
10:30:15> Previous instance active state .: Clear
10:30:15>
10:30:15> Threads
10:30:15> Initialising
10:30:15> ASIO
10:30:15> 0 devices found
10:30:15> CPU
10:30:15> CPU is high power
10:30:15> Logical CPUs: 8
10:30:15> Frequency: 3.615 MHz
10:30:15> Cores on die: 4
10:30:15> Features: [X] Intel Architecture MMX technology supported
10:30:15> Features: [X] Streaming SIMD Extensions
10:30:15> Features: [X] Streaming SIMD Extensions 2
10:30:15> Features: [X] Streaming SIMD Extensions 3
10:30:15> Features: [X] Supplemental Streaming SIMD Extensions 3
10:30:15> Features: [X] The processor supports MOVBE instruction
10:30:15> Features: [X] Streaming SIMD Extensions 4.1
10:30:15> Features: [X] Streaming SIMD Extensions 4.2
10:30:15> Features: [X] Advanced Vector Extensions instruction set
10:30:15> Features: [X] The operating system supports AVX
10:30:15> Features: [X] AES instruction
10:30:15> Features: [X] PCLMULQDQ instruction
10:30:15> Features: [X] Read Random Number instructions
10:30:15> Features: [X] Float16 instructions
10:30:15> Features: [X] Advanced Vector Extensions 2 instruction set (AVX2)
10:30:15> Features: [X] ADCX and ADOX instructions
10:30:15> Features: [X] The RDSEED instruction
10:30:15> Features: [X] The PREFETCHW instruction
10:30:15> Features: [_] Knights Corner instruction set
10:30:15> Cache size: 8388608
10:30:15> Open MP
10:30:15> Threads 2, check 0: 1, 1: 1
10:30:15> Cache
10:30:15> Internal data cache is 400 megabytes
10:30:15> Server Interface
10:30:15> Local initialisation
10:30:15> DLL
10:30:15> File .............: C:\Program Files\SDR-RADIO-PRO.com\SDRSourceAfedriLAN.dll
10:30:15> Name .............: Afedri-SDR (LAN)
10:30:15> Date .............: Jan 17 2020, 21:01:22
10:30:15> Unique ID ........: Afedri-LAN
10:30:15> Version ..........: 1.0.0
10:30:15> -
10:30:15> File .............: C:\Program Files\SDR-RADIO-PRO.com\SDRSourceAfedriUSB.dll
10:30:15> Name .............: Afedri-SDR (USB)
10:30:15> Date .............: Jan 17 2020, 21:02:14
10:30:15> Unique ID ........: Afedri-USB
10:30:15> -
10:30:15> File .............: C:\Program Files\SDR-RADIO-PRO.com\SDRSourceAirspy.dll
10:30:15> Name .............: Airspy
10:30:15> Date .............: Jan 17 2020, 21:03:04
10:30:15> Unique ID ........: Airspy.com
10:30:15> -
10:30:15> File .............: C:\Program Files\SDR-RADIO-PRO.com\SDRSourceAndrusMK1d5.dll
10:30:15> Name .............: SDR MK1.5 Andrus
10:30:15> Unique ID ........: SDR MK1.5 Andrus
10:30:15> -
10:30:15> File .............: C:\Program Files\SDR-RADIO-PRO.com\SDRSourceASIAir.dll
10:30:15> Name .............: ASI Air
10:30:15> Date .............: Jan 17 2020, 21:03:03
10:30:15> Unique ID ........: ASI001
10:30:15> -
10:30:15> File .............: C:\Program Files\SDR-RADIO-PRO.com\SDRSourceBladeRF.dll
10:30:15> Name .............: bladeRF
10:30:15> Date .............: Jan 17 2020, 21:02:24
10:30:15> Unique ID ........: Nuand-BladeRF
10:30:15> -
10:30:15> File .............: C:\Program Files\SDR-RADIO-PRO.com\SDRSourceEladFDMS1.dll
10:30:15> Name .............: ELAD FDM-S1/S2
10:30:15> Date .............: Jan 17 2020, 21:01:37
10:30:15> Unique ID ........: ELAD-FDM-S1LAN
10:30:15> -
10:30:15> File .............: C:\Program Files\SDR-RADIO-PRO.com\SDRSourceEttus.dll
10:30:15> Name .............: Ettus Research (all models)
10:30:15> Date .............: Jan 17 2020, 21:01:33
10:30:15> Unique ID ........: Ettus001
10:30:15> -
10:30:15> File .............: C:\Program Files\SDR-RADIO-PRO.com\SDRSourceFUNcube.dll
10:30:15> Name .............: FUNcube Dongles
10:30:15> Date .............: Jan 17 2020, 21:01:55
10:30:15> Unique ID ........: FUNcube
10:30:15> -
10:30:15> File .............: C:\Program Files\SDR-RADIO-PRO.com\SDRSourceHackRF.dll
10:30:15> Name .............: HackRF
10:30:15> Date .............: Jan 17 2020, 21:02:50
10:30:15> Unique ID ........: HackRF One
10:30:15> -
10:30:15> File .............: C:\Program Files\SDR-RADIO-PRO.com\SDRSourceLime.dll
10:30:15> Name .............: LimeSDR
10:30:15> Date .............: Jan 17 2020, 21:04:17
10:30:15> Unique ID ........: limesdr.org
10:30:15> -
10:30:15> File .............: C:\Program Files\SDR-RADIO-PRO.com\SDRSourceNetSDR.dll
10:30:15> Name .............: RFspace: CloudIQ, CloudSDR, NetSDR, SDR-IP
10:30:15> Date .............: Jan 17 2020, 21:02:01
10:30:15> Unique ID ........: RFspace001
10:30:15> -
10:30:15> File .............: C:\Program Files\SDR-RADIO-PRO.com\SDRSourcePappradio.dll
10:30:15> Name .............: Pappradio
10:30:15> Date .............: Jan 17 2020, 21:02:09
10:30:15> Unique ID ........: Pappradio001
10:30:15> -
10:30:15> File .............: C:\Program Files\SDR-RADIO-PRO.com\SDRSourcePerseus.dll
10:30:15> Name .............: Microtelecom: Perseus
10:30:15> Date .............: Jan 17 2020, 21:01:31
10:30:15> Unique ID ........: Microtelecom001
10:30:15> -
10:30:15> File .............: C:\Program Files\SDR-RADIO-PRO.com\SDRSourceRTLSDR.dll
10:30:15> Name .............: RTL SDR (TCP)
10:30:15> Date .............: Jan 17 2020, 21:01:27
10:30:15> Unique ID ........: RTL SDR (TCP)
10:30:15> -
10:30:15> File .............: C:\Program Files\SDR-RADIO-PRO.com\SDRSourceSDRIQ.dll
10:30:15> Name .............: RFspace: SDR-IQ and SDR-14
10:30:15> Date .............: Jan 17 2020, 21:01:52
10:30:15> Unique ID ........: RFspace002
10:30:15> -
10:30:15> File .............: C:\Program Files\SDR-RADIO-PRO.com\SDRSourceSDRplay.dll
10:30:15> Name .............: SDRplay
10:30:15> Date .............: Jan 17 2020, 21:03:00
10:30:15> Unique ID ........: SDRplay
10:30:15> -
10:30:15> File .............: C:\Program Files\SDR-RADIO-PRO.com\SDRSourceSoftRockSi570.dll
10:30:15> Name .............: SoftRock (Si570)
10:30:15> Date .............: Jan 17 2020, 21:02:33
10:30:15> Unique ID ........: SoftRock (Si570)
10:30:15> -
10:30:15> File .............: C:\Program Files\SDR-RADIO-PRO.com\SDRSourceSoftRockXTAL.dll
10:30:15> Name .............: SoftRock (XTAL)
10:30:15> Date .............: Jan 17 2020, 21:02:22
10:30:15> Unique ID ........: SoftRock (XTAL)
10:30:15> -
10:30:15> MIDI
10:30:15> Starting
10:30:15> Startup
10:30:15> Program started in 3.187 seconds
10:30:15> Input thread
10:30:15> Ok
10:30:15> IPServer
10:30:15> Loading definition
10:30:15> IPServer-Command
10:30:15> Audio
10:30:15> Channel .......................:
10:30:15> Opening .......................: Default Device, (ID = 0)
10:30:15> WAVEFORMATEX.cbSize ...........: 18
10:30:15> WAVEFORMATEX.wFormatTag .......: 1
10:30:15> WAVEFORMATEX.nChannels ........: 2
10:30:15> WAVEFORMATEX.nSamplesPerSec ...: 48000
10:30:15> WAVEFORMATEX.nAvgBytesPerSec ..: 96000
10:30:15> WAVEFORMATEX.nBlockAlign ......: 4
10:30:15> WAVEFORMATEX.wBitsPerSample ...: 16
10:30:15> Error opening Default Device (ID = 0) at 48000Hz - ID out of range, Error code 2
10:30:15> Afedri-SDR (LAN)
10:30:15> DLL initialised
10:30:15> Afedri-SDR (USB)
10:30:15> SDR MK1.5 Andrus
10:30:15> bladeRF
10:30:15> ELAD FDM-S1/S2
10:30:15> Ettus Research (all models)
10:30:15> Boost: Platform=Win32; Compiler=Microsoft Visual C++ version 10.0; Version=Boost_1_56_0
10:30:15> UHD: Version=UHD_3.7.1-0
10:30:15> FUNcube Dongles
10:30:15> HackRF
10:30:15> RFspace: CloudIQ, CloudSDR, NetSDR, SDR-IP
10:30:15> Pappradio
10:30:15> RTL SDR (TCP)
10:30:15> RFspace: SDR-IQ and SDR-14
10:30:15> SDRplay
10:30:15> SoftRock (Si570)
10:30:20> bladeRF
10:30:20> Probing...
10:30:20> Error: No devices found.
10:30:33> Probing...
10:30:33> Error: No devices found.
10:48:22> Settings
10:48:22> Changed, flags 00000000, section Windows
10:48:22> Redraw
11:04:00> bladeRF
11:04:00> Probing...
11:04:00> Error: No devices found.
Re: SDR Console V2.3 Build 3825 Radio Definition Issue
My understanding is that SDRC 2.3 is an obsolete project. I'd not expect to see it handle newer drivers or newer front ends. Simon keeps it around for those who must use it. But he's declared no more changes. He's up to 3.1 now. That may fix your problem.
youngb
Hey Jdow,
That was the problem! I've updated to the newest version. Thanks for your help. =]
Wow - that was a quick fix. Wish they were all this easy. I feel good when somebody is helped or increases their understanding of the RF world.
