activating new Favourites as markers in FFT
Posted: Sun Aug 08, 2021 7:46 am
When adding/edit Favourites they are not automaticly added/changed in the FFT (as a marker).
To activate every change one have to go to View, Markers, Marker Config, uncheck Fav and check Fav again. A bit cumbersome that way.
Is it possible to make a change immediately effective after saving a Favourite? or, if that is more easy for you, by uncheck/check of the main Marker button under View?
Regards, Leon
Regards, Leon
