How can i change the dbm steps in Spectrum?
At the moment there are only 5db steps, i wwould like to change to 10db
Spectrum Scale
Re: Spectrum Scale
I don't think there is an adjustment for that directly but can be achieved by manually setting high/low values for scale here (usually defaults to "auto"):
Re: Spectrum Scale
You can't, it's fixed as Max shows.
Re: Spectrum Scale
At Max s snapshot there are 10db steps.When i change the scale manually like Max, its still at 5db
Re: Spectrum Scale
Ah, that's probably a drawing algorithm.
Re: Spectrum Scale
Ah yes, I can see it changes as you click and drag the horizontal divider bar up and down between spectrum and waterfall.
