Freezing on startup
Posted: Thu Sep 09, 2021 9:49 pm
Hi guys, I have an issue with V3.1, often it freezes on startup. I have 2 profiles, the Main for an RTL-SDR Blog V3 and a second profile for an SdrPlay RSPDX.
At any given time I only have one oif the above SDR's connected.
The installation has mostly worked without issue until recently.
After shutdown and on the next startup the program sometimes freezes on selecting the RSPDX and doesn't complete initialising.
I originally made a copy of the appdata folder (SDR-RADIO.com (V3)) for the installation as a backup.
Once the program freezes, it will not initialise again without either a reset, or by copying the previously saved folder to the appropriate appdata locaton.
Over writing the SDR-RADIO.com (V3) folder in users/appdata/roaming with the backup copy cures the problem which looks like there is perhaps some corruption occurring within that folder.
I suspect that the issue may have started with a W10 update or perhaps may be AV related.
My operating system is W10 with the latest updates installed.
AV is Avast.
CAT controlled set is Kenwood TS-590SG
I also run the kenwood ARCP cointrol software and Voicemeeter Banana. All three applications have happily co-existed until recently.
Any clues as to what is happening here or a fix other than overwriting the appdata/user/roaming/SDR-RADIO.com (V3) folder.
Thanks
Phil
AV is Avast.
Thanks
Phil
