Crash when panning left beyond zero hertz
Posted: Fri Sep 17, 2021 8:10 pm
by norbinz
Repeatable crash in v3.1 (and prior versions):
I left-click within the left half of the waterfall display to pan to lower frequencies. That works fine until the zero-Hertz spike appears and I left-click to the left of it. Then the SDR Console window vanishes and a small popup "Please Wait..." appears for a few seconds. Similar crashing has occurred in every version that I've tried since I began using SDR Console in 2018.
Possibly related: When the zero-Hertz spike appears, the Spectrum pane's x-axis frequency labels no longer align correctly with the plot.
My radio: SDRplay RSPdx (currently), SDRplay RSP2pro (previously)
My PC: Windows 7 64-bit, i7 CPU, 32 GB memory, NVIDIA GTX 1070, desktop 2560x1440 set to Windows Classic Theme.
Re: Crash when panning left beyond zero hertz
Posted: Sat Sep 18, 2021 6:20 am
Hi can you make a full screenshot just before the last click left from the 0 spike?
I don't understand that you can go lower than 0 Hz.
That was possible in the past but it should not be possible anymore. At least not with my RSP2.
Posted: Sat Sep 18, 2021 8:56 am
norbinz wrote: ↑Fri Sep 17, 2021 8:10 pm
Tried very hard to reproduce this with RSP2Pro. Cannot provoke it.
As per Leon's request, please post full uncropped screenshot so that we can see exactly all of your settings immediately before the last click in an attempt to reproduce.
Best
Posted: Sat Sep 18, 2021 9:39 am
by norbinz
That's my superpower: Breaking Stuff.
In both screenshots my cursor (not captured) is slightly left of the "17.070" indicator. If I right-click, the crash occurs.
Also notice the large zero-Hertz spike, and WWVB at 60 kHz, although the x-axis labels it around 97 kHz.
Posted: Sat Sep 18, 2021 12:58 pm
norbinz wrote: ↑Sat Sep 18, 2021 9:39 am
OK. NOW I've reproduced, because in your first post you said left-click to left of cursor the crash occurs. Now I have done a RIGHT click it does indeed crash as you say. Also confirmed with my HL2 so it's not radio dependent.
I don't think I would ever have seen this myself because I can't think why I would be right-clicking at all? Is this to access a feature I don't know about?
Anyway, agreed it does crash!
Posted: Sat Sep 18, 2021 2:59 pm
by norbinz
Doh!
Apologies.
I proof-read my post several times before submitting it, then once again later on, but still didn't catch my typo. Probably a senior moment.
R-I-G-H-T-clicking inside the waterfall pane is how I pan the waterfall left and right to browse the RF bands. Right-click near the center to pan a small amount. Right-click near the sides to pan a large amount. Right-click a signal to pan it to center. I wish it panned faster - the displays pause for about half a second after each right-click.
Posted: Sat Sep 18, 2021 4:15 pm
norbinz wrote: ↑Sat Sep 18, 2021 2:59 pm
Doh!
Apologies.
Strewth, you taught me something there I did not even know existed! I've always moved about in "chunks" by left clicking to left and right of the light grey "span bar" right at the bottom of the screen. Yes, I admit, that is useful. Wonder why I never saw it before?
Anyway, yes agree there's a bug there which I am sure Simon will now fix. Nice spot!
Best
Posted: Thu Sep 23, 2021 6:09 am
thanks for the screenshots, that helped us.
As Max i never use the right click in the WF but it crashed here also.
Posted: Thu Sep 23, 2021 6:26 am
