Simon's World Map v1.2
Posted: Fri Sep 24, 2021 3:46 pm
Getting to know Simon's Map (latest v1.2).
When I set the option to goto Full Screen on startup - it does that.
However when it does startup it briefly shows the menus and map then expands
so that only the map appears on my Laptop screen. OS is Windows 10.
The problem is that I can't reduce the size or exit the application without using
Task Manager.
I've tried following:
Tried unistalling the app and reinstalling
Tried modifying registry setting for this flag in Options)
Tried clearing all Registry settings for this app.
Looked in Run Shell:startup. Only my own Clock, no entry for Simon's Map
Run out of ideas
Cheers JD
Task Manager.
Run out of ideas
Cheers JD
