Page 1 of 2
Shaded, Resolution, Solar
Posted: Mon Oct 11, 2021 11:29 am
by BM46
Special Points Requests
Shaded = For some time this parameter must be reset each time the program is opened. He didn't need it before.
Resolution = The same is true for the value of the chosen resolution, each time the program is opened, the value must be chosen again.
Too bad to have to reset these two parameters each time you open the program
These parameters should normally be recognized at each opening.
Another point.
Like the choice to display or not: Clock, Statistics, Frequency
have the possibility to display in addition the parameters: Solar Flux, Regions, Sunspots and A, K
Thank you in advance
Best regards
Re: Shaded, Resolution, Solar
Posted: Mon Oct 11, 2021 1:37 pm
- What version are you using? Get the latest kit please.
- Ribbon Bar, View, Waterfall Extras.
Posted: Mon Oct 11, 2021 3:47 pm
by BM46
ELAD FDM-S3 = Version 3.1 Build 2385
Posted: Mon Oct 11, 2021 4:21 pm
by BM46
I just launched V3.1, October 11, 2021 = SDR-Radio V3.1, 64-bit, 2021-10-11_1117.exe
For this new version the program freezes very quickly
For my previous request, is not the waterfall zone lower part that is concerned but the upper part area which is without the shaded function
It's the same with your new version regarding shaded
I send you a Screenshot
Posted: Mon Oct 11, 2021 4:55 pm
BM46 wrote: ↑Mon Oct 11, 2021 4:21 pm
- Ribbon Bar, Tools, Settings, uncheck Low Power.
Posted: Tue Oct 12, 2021 6:13 am
by BM46
I can't find "LowPower. "
Posted: Tue Oct 12, 2021 6:18 am
by BM46
OK seen
Posted: Tue Oct 12, 2021 6:32 am
by BM46
Even with the "Low Power" option, the sound still works but the image freezes very quickly
Posted: Tue Oct 12, 2021 6:42 am
BM46 wrote: ↑Tue Oct 12, 2021 6:32 am
You don't need the low power option.
If the program freezes then I expect it's USB-related. Try a lower bandwidth, only use 24 MHz if really necessary.
Posted: Tue Oct 12, 2021 6:55 am
by BM46
Increased memory, in permanence, until the program crashes
