Startup Error: this action cannot be completed because the other program is busy
Posted: Wed Oct 20, 2021 8:46 pm
by N5ANY
When I start the program (v 3.1) I get a message:
I am using a Yaesu FTDX5000 , omni rig, the Yaesu SCU-17 and an SDR Play. Sometimes after hitting the switch to button several times the box goes away and I can start the program. Any suggestions on how to make this switch to box go away?
73's Chuck Bigbie N5ANY
Re: Startup Error: this action cannot be completed because the other program is busy
Posted: Thu Oct 21, 2021 2:39 pm
I suspect the Server is still running and uses the SDRplay to.... ?
Posted: Mon Jan 24, 2022 1:29 pm
by rv6fx
Same problem.
Everything works as long as Only sdr console talks with omni-rig server.
An attempt to run, for example, wsjt-x or log, which also want to communicate with omni, does not work. Programs do not see omni-rig.
Even more interesting, when running wsjt + log, which by themselves normally see the omni-rig server, I try to enable external radio in the console.
Now sdr-console doesn't see omni-rig , it prompts to repeat, and then through the loop, from which you can only exit by killing the process through the program manager.
Posted: Thu Jan 27, 2022 5:25 pm
by rv6fx
Simon!
Thanks a lot, everything works now! (Build 2496)
I was able to connect to the omni-rig sdr-console. wsjt and logger.
Posted: Fri Jan 28, 2022 5:44 pm
by rv6fx
Unfortunately, everything worked only until the reboot. After a reboot, it is again impossible to run 3 programs at the same time, using omni-rig.
I can run wsjt-x + sdr-console, but only if wsjt is started first. If i close both programs then restart external radio (omni) in sdr-console i can only, if I reboot my computer
Maybe a flag is set somewhere and not cleared on exit?
