is it possible to turn FFT Display off?
Posted: Thu Sep 03, 2020 8:45 pm
by p3t3
Hi guys.
I would like to set up sdr-console to feed 4 channels /each to different VAC output/. I am using RSP1A - and that covers up to 10MHz spectrum. The problem is that it's working if I use RTL-SDR with 2MHz visible spectrum, but when I try to use RSP1A and I select 8MHz bandwith, then the computer RAM usage is too high and everything freezes.. So I thought - how could I lower the memory usage? I actually do not need waterfall or any indication, because the channels are fixed. And I thought maybe turning off the FFT display might help it... But I did not find how to turn it off.. maybe you have other suggestions..
thanks,
p3t3
Re: is it possible to turn FFT Display off?
Posted: Fri Sep 04, 2020 2:55 pm
p3t3 wrote: ↑Thu Sep 03, 2020 8:45 pm
Hi guys.
thanks,
p3t3
Tell me about
your PC. You can restrict the RAM use, using RAM will not be the problem, I expect it's CPU.
Posted: Sun Sep 06, 2020 1:47 pm
by p3t3
Well,
I will need a new computer for sure, this one is a spare notebook sitting on a shelf, so I thought I might get it to do something useful. I'll post some screenshots on how the memory gets too high when I uplug RTL-SDR and plug RSP1A. You can see it in the graph too. You can see the computer specs next to task manager screenshot /rtl-sdr plugged in/. The sdr console is minimised.. I am not sure if the possibility of turning the display off would help anything, I was just thinking and wondering if it might do any help.. Or maybe other settings will help too.
Thank you for your time
p3t3
Simon G4ELI wrote: ↑Fri Sep 04, 2020 2:55 pm
Hi guys.
thanks,
p3t3
Tell me about
Posted: Mon Sep 07, 2020 2:49 pm
Hi guys.
thanks,
p3t3
In 3.0.25 there's an option the decrease the FFT resolution, this can save a lot of CPU cycles.
Posted: Wed Sep 09, 2020 6:33 am
by p3t3
hello,
so I'll have to wait for the 3.0.25 version then.
thanks,
p3t3
