Re: 6 meter band receivable ?
Posted: Fri Dec 03, 2021 10:16 pm
Odd. My logic says that what you are seeing is direct sampling of anything received on the H port, and indirect via tuner on the V port?
The only thing I see from Paul's description is that there is most likely some crossover between the two tuning ranges i.e. the VHF tuner goes down to about 30 MHz maybe?
Is this not confirmed by Paul seeing some small level differences? Also could be confirmed by how much bandwidth you can see either side of the centre frequency depending on whether the antenna is connected to H or V. I'd expect to see 32 MHz bandwidth available on the H port?
