Simon, Airspy #1 at your QTH is inop
Posted: Mon Apr 18, 2022 1:03 pm
Does nothing when trying to operate.
Here's what I copied:
Connecting to 81.174.138.141::50101
Connected
Sending <SVRMsg Command="Radios" Username="Guest" Password="GuestPwd"></SVRMsg>
Reply
XML: <SVRMsg Command="Radios" Defns="<SDRRadio><RadioDefn Accounts="" Address="3652E880ECDC38D3" Bandwidths="" DllID="Airspy HF+" Enable="1" InUse="1" Model="Airspy HF+" Options="Board revision 1" Port="0" RangeHigh="250000000" RangeLow="0" Serial="3652E880ECDC38D3" Title="Airspy HF+ #1" VisualGain="0"/><RadioDefn Accounts="" Address="C852D65DEF3839F7" Bandwidths="" DllID="Airspy HF+" Enable="1" InUse="1" Model="Airspy HF+" Options="Board revision 2" Port="0" RangeHigh="250000000" RangeLow="0" Serial="C852D65DEF3839F7" Title="Airspy HF+ #2" VisualGain="0"/><RadioDefn Accounts="" Address="1721-061C-5345303339355F30303034000000000000000000000000000000000000000000" Bandwidths="" DllID="ELAD-FDM-S1LAN" Enable="1" InUse="1" Model="FDM-S2" Options="" Port="0" RangeHigh="160000000" RangeLow="0" Serial="SE0395_0004" Title="FDM-S2" VisualGain="0"/><RadioDefn Accounts="" Address="USB" Bandwidths="" DllID="Microtelecom001" Enable="1" InUse="0" Model="Perseus 1.0" Options="Hardware = 1.0, Product code = x8014" Port="0" RangeHigh="30000000" RangeLow="0" Serial="03981-2107-5FAE-3A5E" Title="Perseus 1.0" VisualGain="0"/></SDRRadio>" Error="Valid"></SVRMsg>
Command: Radios
Status: Valid
Defns: <SDRRadio><RadioDefn Accounts="" Address="3652E880ECDC38D3" Bandwidths="" DllID="Airspy HF+" Enable="1" InUse="1" Model="Airspy HF+" Options="Board revision 1" Port="0" RangeHigh="250000000" RangeLow="0" Serial="3652E880ECDC38D3" Title="Airspy HF+ #1" VisualGain="0"/><RadioDefn Accounts="" Address="C852D65DEF3839F7" Bandwidths="" DllID="Airspy HF+" Enable="1" InUse="1" Model="Airspy HF+" Options="Board revision 2" Port="0" RangeHigh="250000000" RangeLow="0" Serial="C852D65DEF3839F7" Title="Airspy HF+ #2" VisualGain="0"/><RadioDefn Accounts="" Address="1721-061C-5345303339355F30303034000000000000000000000000000000000000000000" Bandwidths="" DllID="ELAD-FDM-S1LAN" Enable="1" InUse="1" Model="FDM-S2" Options="" Port="0" RangeHigh="160000000" RangeLow="0" Serial="SE0395_0004" Title="FDM-S2" VisualGain="0"/><RadioDefn Accounts="" Address="USB" Bandwidths="" DllID="Microtelecom001" Enable="1" InUse="0" Model="Perseus 1.0" Options="Hardware = 1.0, Product code = x8014" Port="0" RangeHigh="30000000" RangeLow="0" Serial="03981-2107-5FAE-3A5E" Title="Perseus 1.0" VisualGain="0"/></SDRRadio>
Count: 4
Connected
Sending <SVRMsg Command="Bandwidth" Model="Airspy HF+" Title="Airspy HF+ #1"></SVRMsg>
Reply
XML: <SVRMsg Command="Bandwidth" Bandwidth="30000,40000,50000,75000,100000" Status="✓"></SVRMsg>
Command: Bandwidth
Status: ✓
Bandwidths: 30000,40000,50000,75000,100000
Closed
Closed
Connected
Sending <SVRMsg Command="Soundcards"></SVRMsg>
Reply
XML: <SVRMsg Command="Soundcards" Soundcard="Line 1 (Virtual Audio Cable)	Microphone Array (Realtek(R) Audio)"></SVRMsg>
Command: Soundcards
Error:
Soundcards: Line 1 (Virtual Audio Cable) Microphone Array (Realtek(R) Audio)
Closed
PS Was trying to see if your SDR's can hear the 17M QRM (OTHR?) on the top end of 17M.
Connected
Reply
Command: Radios
Status: Valid
Count: 4
Connected
Reply
Command: Bandwidth
Status: ✓
Closed
Closed
Connected
Reply
Command: Soundcards
Error:
Closed
