OpenCL on Celeron boards
Posted: Sun May 08, 2022 3:30 pm
I am considering building a small, low-power system using this board:
https://www.supermicro.com/en/products/ ... d/x12stn-c
I see that the Intel® Celeron® 6305E Processor has internal UHD GPU with OpenCL 2.0 support. The idea is to use this for remote monitoring over RDP. Do you think this CPU and GPU would work with sdr-radio with about a 8-10MHz FFT using something like a SDRPlay? I would access remotely using RDP on hardwired LAN. Audio would be transmitted from this PC to a Dante audio network, so there should be very little audio latency.
