Windows display doesn't turn off
Posted: Sat Jun 04, 2022 3:33 pm
My question is about how to turn off the display in Windows while SDR-Console is running. I have had this issue with both Windows 10 and Windows 11. If SDR-Console is open, Windows will not turn off the display after X minutes (whatever is set). This is true even if SDR-Console is minimized.
I've done a lot of research on Windows websites about this issue of the display not automatically turning off. The usual answer is to locate the app that is causing the problem and close it. That doesn't solve my problem since I want the app to run.
Why would I run SDR-Console with the monitor off? I do lots of spectrum recording while traveling. Sometimes (like this weekend) I am somewhere with noise coming in through the electric power lines. If I unplug the laptop and run off battery then the noise goes away. But if the display stays on that uses my battery faster. I don't have enough power to run unattended overnight. If my display would turn off then I could easily record all night off of battery power.
Does anyone know of a solution to this problem? BTW, this is not a problem with HDSDR - Windows will turn off the display when that program is running. But I prefer to use SDR-Console.
