Decoding of Digital Signals using DSD plus
⭐ All other software not in the list below, e.g. Log4OM
anilsrk0
Unread post by anilsrk0 »
hi all,
I want to listen digital voice in sdr console software. i installed DSD plus and also Made VB Cable Setup . Now i can decode the Talk group ID and Radio ID but not the digital Voice. so how we can listen digital Voice in sdr consle..
Thanks in Advance
Re: Decoding of Digital Signals using DSD plus
Wrong sideband? ID might not be sensitive to wrong sideband, voice might be. But, that is just guessing - what is your installation? Full size pictures showing the whole window to show settings? and so forth. Without pictures the only option we have is to assume you are a naif beyond help who cannot read. Becoming monkey in the middle with one of those can be painful and sticky. (And, yes, I am feeling my inner Aspie tonight.)
Jerry Newsome
Unread post by Jerry Newsome »
Try using W-FM mode then set Filter to 12.5 or 30. If the talk group is encrypted you will not get any voice decode
