RX-888 Mk2 not working
mstangelo
Unread post by mstangelo »
I occasionally use my RX-888 Mk2. I just loaded Simons's latest v3.2 SDRC software and tried it out. The RX-888 Mk2 was not discovered. I tried my original RX-888 ad that is working. I believe the hardware has issues.
Can anyone suggest any troubleshooting tips for my Mk2?
All of my SDR receiver is fed by and active W8ZR HF Multicoupler so I don't suspect EMI issues via the antenna port. I once kept it powered up for a couple of hours so heat may have damaged a chip.
I like viewing a wide portion of bandwidth 8 to 32 Mhz. Could anyone suggest another SDR which can receive a wide spectrum at a reasonable price. Are there any new products coming onto the market this year?
If I elect to buy another RX-888 Mk2 can anyone recommend a reputable vendor?
Thanks, Mike N2MS
Re: RX-888 Mk2 not working
I've been threatening to create a source dll for that beast. (I have one.) Other things keep getting in the way. I have all the RX888 end of things under control, even if multiple rx888 devices are connected. I need to fumble through the source dll part of the picture.
Radioman
Unread post by Radioman »
I can only use 1MHz bandwidth on my RX888 in sdr radio or stutter occurs. On the same pc I can use 25Mhz bandwidth with HDSDR software.
Steve M0ZEH
