SDR Console with Log4OM
oe8act
Unread post by oe8act »
Hello!
My goal is to log QO-100 contacts with Log4OM. I do both TX and RX with an Adalm Pluto.
I'm wondering if it is possible to link the frequency and mode from SDR Console to Log4OM with the help of K5FR's VSP Manager and Omnirig?
I tried following steps:
- installed a virtual com port pair with VSP Manager (COM 12 and COM 13)
- Omnirig settings: Rig type: TS-2000, COM 12, 57600, 8, none, 1, low, low, 100ms, 100ms
- SDR Console: In program options: checked COM 13 in CAT (Serial Port) port selection settings
Unfortunately no success. Log4OM seems to start the CAT interface but shows a completely different frequency (for example 1.899.758.983 instead of 10.489.800.825). When clicking on another frequency in the
SDR Console waterfall window the frequency suddenly jumps from 10GHz to the 1.8GHz range.
Is there anyone who got it running with this setup?
Thanks in advance for your replies,
73 de OE8ACT - Patrick
Re: SDR Console with Log4OM
Simon is a little preoccupied at the moment. I suspect he will want a full size picture showing the problem and as many of the settings for SDRC as you can manage. I suspect I know what sort of problem it is. What is your conversion frequency setting? And have you set it up to show 99.9 GHz rather than 9.9 GHz? (Tools->Display->Spectrum in the top most grouping on that panel.)
