Reducing the bandwidth of ethernet?
Also known as ADALM-PLUTO.
Dandex
Unread post by Dandex »
Hello.
I try to run my Pluto over a VPN, but this VPN is a bit slow, so there is no continious sound out of the Console. Is it possible to reduce the bandwidth/samplingrate or what else, to get a smaller datasize?
I hope for any help.
'73 Daniel DO5FDR
Re: Reducing the bandwidth of ethernet?
Reduce the screen / minimise the program.
Dandex
Simon G4ELI wrote: Fri Oct 07, 2022 9:51 am Reduce the screen / minimise the program.
I mean my network is overloaded. Does minimizing the window really help?
Reduce the selected Pluto to the lowest possible sample rate that it supports. If that does not work there's likely nothing more that can be done.
