QO-100/Pluto - Report TX frequency via CAT
Posted: Mon Nov 14, 2022 3:56 pm
I am using SDR-Radio (v3.2) for QO-100 with a Pluto SDR. All working fine from the operating standpoint.
Now, I am wondering if there is a way to set the program up so that the TX frequency (on 2.4G) is sent via CAT rather than the RX (and displayed frequency). The reason behind the request is that SAT QSOs for confirmation on LoTW need to have the TX band set to 2.4G. My logging program logs 10G though because that is coming via CAT.
To work around that, I currently have my Transverter settings set to show 2.4G for both but that way I am losing for example the option to use the beacon for offset correction.
Ideally I'd like to be able to show the 10G frequency in the Receive window and 2.4G in the Transmit window and still be able to track the two with the appropriate offset and report TX frequency (or both) via CAT.
What are others doing?
73 Carsten G0SYP
73 Carsten G0SYP
