Improvement to notch filter
Posted: Sat Dec 10, 2022 7:30 am
I'd like to have an adjustable notch filter where you can enter in a frequency that you want notched, as well as an adjustable slider that changes the frequency of the notch, +/- several kHz either side of zero. I've found that the current setup doesn't really give you a lot of control and often notches out the wrong signal if you have multiple hets.
