SDR Conole 3.3 Build 2848 Crash Issue
Posted: Fri Jan 20, 2023 6:24 pm
SDR Console 3.3 Build 2848 will crash (at least for me) if there is an attempt to right click on an open area of the toolbar. Since nobody else has posted a report about this, I am not sure if this behavior is unique to me or not. I am able to repro this in a new empty identity so I don't think it's just me. But who knows. When SRC crashes, the ubiquitous "Please Wait" shows up but never leaves so SDC has to be killed in Task Manager.
In the previous iterations of SDC one could select a Quick Access Toolbar command option for SNR and with the release of 2848, that appears to be gone. In my case, my default meter is digital in SNR. But sometimes I want to switch to S units or dBm for signal strength from the Quick Access Toolbar which I can still do. But now I can no longer get out of or back into SNR without hunting through the menu options.
Since release notes indicate work is apparently being done in the Ribbon Bar neighborhood, I thought I would mention a few quirks with the Quick Access Toolbar that are still unaddressed such as the Separator Bar not being retained after the next restart of SDC nor any Quick Access option that is only present when SDC is running (i e Bandwidth, etc.). Also there is no Quick Access option for anything in the DSP Panel (such as modes and filters). Additionally many options in the Quick Access Toolbar menu are ambiguous as to exactly which function they tied to.
The smaller icons for Favorites is nice...it might be helpful if there could be some way to change all icons in one pass to small or large in addition to the existing ability to change them one at a time.
