mode AM instead of mode SAM
nik_aga
Unread post by nik_aga »
Hi!
NO ONE KNOWS HOW TO DO IT.
Contacting developers:
How to set "Favorites>Broadcast :: HF" to default mode AM instead of mode SAM?
Thanks in advance.
Re: mode AM instead of mode SAM
Recall the Favourite. Change Mode to AM.
On Favourites ribbon bar, press "Update". Set the tick boxes how you like then then press "OK". Job done. Do this for every Favourite in turn.
See here for what a Favourite stores and also what options are:
https://www.sdr-radio.com/Favourites
nik_aga
Thank you. Super!
lappydesktop
Unread post by lappydesktop »
I only found out a few days ago that that also works for the zoom factor on a memory so one can have a specific zoom level for a specific memory , on some of the memories i have they are jammed in amongst several high power SW stations and was continually zooming in on the band after clicking a memory
Paul
