Adalm Pluto - Full Duplex
Posted: Sat Sep 16, 2023 1:50 pm
Hello, I have a problem using the Adalm-Pluto together with the SDR-console for QO-100 communications. So far, everything works fine except of full duplex. Anytime I switch from RX to TX the console waterfall becomes completely noisy and no signal is received anymore. All full duplex adjustments were done in the console. For debugging I tried to reduce the output power of the pluto in the console but even for very small values the mentioned phenomenon occurs. Therefore I guess it is not a HF problem (e.g. interference between TX and RX branches) but rather a software problem within the pluto, maybe a missing variable setting.
Does anybody has an idea to circle the problem or even solving it.
Thanks in advance!
Gero
Thanks in advance!
Gero
