Cant access FM duo via SDR server
Moderator: NN4F
VK7JEM
Unread post by VK7JEM »
I have tried to capture diagnostics so apologies for long post
Having problem with ELAD FMduo and SDR server.
It was working up til 2 weeks ago.
My setup have a win 11 laptop running v3117 (sdrserver) with an airspy hf+ discovery and elad fm-duo txrx on usb ports
Also have 2 laptops running win 10 and win 11 also with 3117 (different rooms same lan)
On sdrserver laptop I can happily use both airspy and elad either locally or rdp no problems
However on both remote clients I can only connect to airspy but when I try to connect to elad it says connecting but nothing happens.
No audio, no waterfall, so signal.
I have completely uninstalled SDR console from my sdr server via Revo and reinstalled and re set up sdr server
And done a fresh reinstall of win 10 on one of the clients... cno change
On the log file of the remote clients when trying to connect to elad I see
01:32:07.836: Radio V3Server> -
01:32:08.781: Radio V3ServerTCP> Read failure: error 10060 = Connection timed out.
01:32:09.786: Radio V3ServerTCP> Read failure: error 10060 = Connection timed out.
01:32:09.814: Radio V3ServerTCP> Read failure: error 10054 = Connection reset by peer.
01:32:09.816: Radio V3ServerTCP> Read failure: read = 0 of 20, error code 10054 = Connection reset by peer.
01:32:14.994: Select Radio> Stopping: disable reader thread
01:32:14.994: Radio V3Server> Sending empty buffer, return code Connection reset by peer.
01:32:14.994: Radio V3Server> Error sending buffer [0] of 2, 20 bytes, return code Connection reset by peer.
01:32:14.995: Select Radio> Stopping: close radio
01:32:14.995: Radio V3Server> Error sending buffer <SVRMsg Command="Close"></SVRMsg>...
01:32:14.995: Radio V3Server> Closing...
01:32:14.995: Radio V3Server> Closed
01:32:14.996: Select Radio> Stopping: stop reader thread
01:32:14.996: Select Radio> Stopping: reset radio
and on event vwr or sdrserver I see
Faulting application name: SDRServerService.exe, version: 1.0.0.1, time stamp: 0x6523ce15
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x0000000000000000
Faulting process id: 0x3198
Faulting application start time: 0x01da04f70ee8016f
Faulting application path: C:\Program Files\SDR-Radio.com (V3)\SDRServerService.exe
Faulting module path: unknown
Report Id: f436cfeb-6d6a-4d26-a51e-54c8b614e5d9
Faulting package full name:
Faulting package-relative application ID:
</Event>
Fault bucket 1883518840339321520, type 5
Event Name: BEX64
Response: Not available
Cab Id: 0
Problem signature:
P1: SDRServerService.exe
P2: 1.0.0.1
P3: 6523ce15
P4: StackHash_ac46
P5: 0.0.0.0
P6: 00000000
P7: PCH_3D_FROM_ntdll+0x00000000000A4844
P8: c0000005
P9: 0000000000000008
P10:
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_SDRServerService_cafc8f2533bd91ea8528ec27ba079de7667bbd9_e9147559_b26ec715-adf7-40d3-b1f1-4a049516ea69
Analysis symbol:
Rechecking for solution: 0
Report Status: 268435456
Hashed bucket: c73fcc92a0895ac62a239a67ee2e52b0
Cab Guid: 0
The SDR-Radio.com V3 Remote server, visit sdr-radio.com for more info service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 1000 milliseconds: Restart the service.
The WER reads
01:32:07.815: Select Radio> Status .....: OK
01:32:07.815: Radio V3Server> Change frequency, buffer rest (current 0 samples)
01:32:07.816: Radio Reader> Read interval = 5 (Default)
01:32:07.816: Select Radio> Starting
01:32:07.816: Select Radio> --------
01:32:07.817: Select Radio> Bandwidth ..: 768000
01:32:07.817: Select Radio> PPM ........: 0
01:32:07.818: Select Radio> -
01:32:07.818: CSDRFFTApp::Initialise
01:32:07.818: CUDA Enabled 1
01:32:07.819: -
01:32:07.819: CUDA disabled, no devices, no best device
01:32:07.819: Intel IPP
01:32:07.820: ---------
01:32:07.820: Target CPU: l9
01:32:07.820: Name: ippSP AVX2 (l9)
01:32:07.821: Version: 2020.0.2 (r0xbb6c2c1d)
01:32:07.822: Build date: Jun 23 2020
01:32:07.822: -
01:32:07.822: Logical CPUs: 4
01:32:07.823: -
01:32:07.823: Features: [X] MMX ..... Intel Architecture MMX
01:32:07.823: Features: [X] SSE ..... Streaming SIMD Extensions
01:32:07.823: Features: [X] SSE2 .... Streaming SIMD Extensions 2
01:32:07.824: Features: [X] SSE3 .... Streaming SIMD Extensions 3
01:32:07.824: Features: [X] SSE3S ... Streaming SIMD Extensions 3 (supplemental)
01:32:07.824: Features: [X] SSE4.1 .. Streaming SIMD Extensions 4.1
01:32:07.825: Features: [X] SSE4.2 .. Streaming SIMD Extensions 4.2
01:32:07.825: Features: [X] AVX ..... Advanced Vector Extensions 1 instruction set
01:32:07.825: Features: [X] AVX2 .... Advanced Vector Extensions 2 instruction set
01:32:07.826: Features: [X] The operating system supports AVX
01:32:07.826: Features: [X] The processor supports MOVBE instruction
01:32:07.826: Features: [X] AES instruction
01:32:07.826: Features: [X] PCLMULQDQ instruction
01:32:07.827: Features: [X] Float16 instructions
01:32:07.827: Features: [X] ADCX and ADOX instructions
01:32:07.827: Features: [X] The RDSEED instruction
01:32:07.828: Features: [X] The PREFETCHW instruction
01:32:07.828: Features: [_] Knights Corner instruction set
01:32:07.828: -
01:32:07.829: FFT IPP> initialising, lines/second = 20, resolution = x4, FFT size = 256k, FFT overlap = 85%
01:32:07.829: FFT IPP> OK
01:32:07.830: FFT IPP> initialising, lines/second = 40, resolution = x4, FFT size = 128k, FFT overlap = 85%
01:32:07.830: FFT IPP> OK
01:32:07.830: Radio V3Server> Buffering
01:32:07.831: Radio V3Server> Bandwidth: 768000 Hz
01:32:07.831: Radio V3Server> Buffer size: 3072000
01:32:07.831: Radio V3Server> -
01:32:07.832: Radio V3Server> Threshold: 211200
01:32:07.832: Radio V3Server> Limit 1: 211200
01:32:07.832: Radio V3Server> Limit 2: 441600
01:32:07.833: Radio V3Server> Size: 3072000
01:32:07.833: Radio V3Server> -
01:32:07.833: Radio V3Server> Threshold: 275 ms
01:32:07.834: Radio V3Server> Limit 1: 275 ms
01:32:07.834: Radio V3Server> Limit 2: 575 ms
01:32:07.834: Radio V3Server> Size: 4000 ms
01:32:07.835: Radio V3Server> -
01:32:07.835: Radio V3Server> Buffer
01:32:07.835: Radio V3Server> Size: 3072000 samples
01:32:07.835: Radio V3Server> Threshold: 211200 samples
Version=1
EventType=BEX64
EventTime=133424598859897780
ReportType=2
Consent=1
UploadTime=133424598864217768
ReportStatus=268435456
ReportIdentifier=b26ec715-adf7-40d3-b1f1-4a049516ea69
IntegratorReportIdentifier=f436cfeb-6d6a-4d26-a51e-54c8b614e5d9
Wow64Host=34404
NsAppName=SDRServerService.exe
OriginalFilename=SDRServerService.exe
AppSessionGuid=00003198-0000-008d-6f01-e80ef704da01
TargetAppId=W:000041cfe90881587dcda0862ed4a6053d8f0000ffff!0000fa760f67b7cfcc431f848c558b64be32c0f542ec!SDRServerService.exe
TargetAppVer=2023//10//09:09:55:33!481f6!SDRServerService.exe
BootId=4294967295
ServiceSplit=2028982968
TargetAsId=652
IsFatal=1
EtwNonCollectReason=1
Response.BucketId=c73fcc92a0895ac62a239a67ee2e52b0
Response.BucketTable=5
Response.LegacyBucketId=1883518840339321520
Response.type=4
Sig[0].Name=Application Name
Sig[0].Value=SDRServerService.exe
Sig[1].Name=Application Version
Sig[1].Value=1.0.0.1
Sig[2].Name=Application Timestamp
Sig[2].Value=6523ce15
Sig[3].Name=Fault Module Name
Sig[3].Value=StackHash_ac46
Sig[4].Name=Fault Module Version
Sig[4].Value=0.0.0.0
Sig[5].Name=Fault Module Timestamp
Sig[5].Value=00000000
Sig[6].Name=Exception Offset
Sig[6].Value=PCH_3D_FROM_ntdll+0x00000000000A4844
Sig[7].Name=Exception Code
Sig[7].Value=c0000005
Sig[8].Name=Exception Data
Sig[8].Value=0000000000000008
DynamicSig[1].Name=OS Version
DynamicSig[1].Value=10.0.22000.2.0.0.256.48
DynamicSig[2].Name=Locale ID
DynamicSig[2].Value=3081
DynamicSig[22].Name=Additional Information 1
DynamicSig[22].Value=ac46
DynamicSig[23].Name=Additional Information 2
DynamicSig[23].Value=ac462b2fd07cc853b652b5104a1cf381
DynamicSig[24].Name=Additional Information 3
DynamicSig[24].Value=1cc5
DynamicSig[25].Name=Additional Information 4
DynamicSig[25].Value=1cc548d37b58939c6f465e025cce92bd
UI[2]=C:\Program Files\SDR-Radio.com (V3)\SDRServerService.exe
UI[5]=Close
UI[8]=SDR Server service (V3) stopped working and was closed
UI[9]=A problem caused the application to stop working correctly. Windows will notify you if a solution is available.
UI[10]=&Close
LoadedModule[0]=C:\Program Files\SDR-Radio.com (V3)\SDRServerService.exe
LoadedModule[1]=C:\WINDOWS\SYSTEM32\ntdll.dll
LoadedModule[2]=C:\WINDOWS\System32\KERNEL32.DLL
LoadedModule[3]=C:\WINDOWS\System32\KERNELBASE.dll
LoadedModule[4]=C:\WINDOWS\System32\USER32.dll
LoadedModule[5]=C:\WINDOWS\System32\win32u.dll
LoadedModule[6]=C:\WINDOWS\SYSTEM32\mfc140u.dll
LoadedModule[7]=C:\WINDOWS\System32\GDI32.dll
LoadedModule[8]=C:\WINDOWS\System32\ADVAPI32.dll
LoadedModule[9]=C:\WINDOWS\System32\gdi32full.dll
LoadedModule[10]=C:\WINDOWS\System32\msvcrt.dll
LoadedModule[11]=C:\WINDOWS\System32\msvcp_win.dll
LoadedModule[12]=C:\WINDOWS\System32\ucrtbase.dll
LoadedModule[13]=C:\WINDOWS\System32\sechost.dll
LoadedModule[14]=C:\WINDOWS\System32\RPCRT4.dll
LoadedModule[15]=C:\WINDOWS\System32\SHELL32.dll
LoadedModule[16]=C:\WINDOWS\System32\ole32.dll
LoadedModule[17]=C:\WINDOWS\System32\OLEAUT32.dll
LoadedModule[18]=C:\WINDOWS\System32\combase.dll
LoadedModule[19]=C:\WINDOWS\System32\SHLWAPI.dll
LoadedModule[20]=C:\WINDOWS\System32\IMM32.dll
LoadedModule[21]=C:\WINDOWS\SYSTEM32\VCRUNTIME140_1.dll
LoadedModule[22]=C:\WINDOWS\SYSTEM32\VCRUNTIME140.dll
LoadedModule[23]=C:\WINDOWS\SYSTEM32\VERSION.dll
LoadedModule[24]=C:\WINDOWS\SYSTEM32\UxTheme.dll
LoadedModule[25]=C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.22000.2003_none_caca4feb15c6e062\Comctl32.dll
LoadedModule[26]=C:\WINDOWS\SYSTEM32\windows.storage.dll
LoadedModule[27]=C:\WINDOWS\SYSTEM32\wintypes.dll
LoadedModule[28]=C:\WINDOWS\System32\SHCORE.dll
LoadedModule[29]=C:\WINDOWS\SYSTEM32\profapi.dll
LoadedModule[30]=C:\WINDOWS\SYSTEM32\kernel.appcore.dll
LoadedModule[31]=C:\WINDOWS\System32\bcryptPrimitives.dll
LoadedModule[32]=C:\WINDOWS\SYSTEM32\CFGMGR32.dll
LoadedModule[33]=C:\WINDOWS\System32\clbcatq.dll
LoadedModule[34]=C:\WINDOWS\system32\propsys.dll
LoadedModule[35]=C:\WINDOWS\SYSTEM32\ntmarta.dll
LoadedModule[36]=C:\Program Files\SDR-Radio.com (V3)\SDRServerMainDLL.dll
LoadedModule[37]=C:\WINDOWS\System32\WS2_32.dll
LoadedModule[38]=C:\WINDOWS\SYSTEM32\MSVCP140.dll
LoadedModule[39]=C:\Program Files\SDR-Radio.com (V3)\DSPFunctions.dll
LoadedModule[40]=C:\Windows\System32\msxml6.dll
LoadedModule[41]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceAfedriLAN.dll
LoadedModule[42]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceAfedriUSB.dll
LoadedModule[43]=C:\WINDOWS\System32\SETUPAPI.dll
LoadedModule[44]=C:\WINDOWS\SYSTEM32\WINMM.dll
LoadedModule[45]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceAirspy.dll
LoadedModule[46]=C:\Program Files\SDR-Radio.com (V3)\pthreadVC2.dll
LoadedModule[47]=C:\WINDOWS\SYSTEM32\MSVCR100.dll
LoadedModule[48]=C:\Program Files\SDR-Radio.com (V3)\shark.dll
LoadedModule[49]=C:\WINDOWS\SYSTEM32\RICHED20.DLL
LoadedModule[50]=C:\WINDOWS\SYSTEM32\USP10.dll
LoadedModule[51]=C:\WINDOWS\SYSTEM32\msls31.dll
LoadedModule[52]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceAirspyHFPlus.dll
LoadedModule[53]=C:\Program Files\SDR-Radio.com (V3)\airspyhf.dll
LoadedModule[54]=C:\Program Files\SDR-Radio.com (V3)\libusb-1.0.dll
LoadedModule[55]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceAirspyServer.dll
LoadedModule[56]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceAndrusMK1d5.dll
LoadedModule[57]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceArinst.dll
LoadedModule[58]=C:\Program Files\SDR-Radio.com (V3)\arinst_usb_dll.dll
LoadedModule[59]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceBladeRF.dll
LoadedModule[60]=C:\Program Files\SDR-Radio.com (V3)\bladeRF.dll
LoadedModule[61]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceBladeRFv2.dll
LoadedModule[62]=C:\Program Files\SDR-Radio.com (V3)\bladeRFv2.dll
LoadedModule[63]=C:\WINDOWS\SYSTEM32\MSVCR120.dll
LoadedModule[64]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceEladDUOr.dll
LoadedModule[65]=C:\Program Files\SDR-Radio.com (V3)\ELAD_basic_USB.dll
LoadedModule[66]=C:\WINDOWS\SYSTEM32\WINUSB.DLL
LoadedModule[67]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceEladDUOtx.dll
LoadedModule[68]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceEladFDMS1.dll
LoadedModule[69]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceEladS3.dll
LoadedModule[70]=C:\Program Files\SDR-Radio.com (V3)\ELAD_basic_USB_FX3_v2_1_1_0_x64.dll
LoadedModule[71]=C:\WINDOWS\System32\COMDLG32.dll
LoadedModule[72]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceEttus.dll
LoadedModule[73]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceFUNcube.dll
LoadedModule[74]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceHackRF.dll
LoadedModule[75]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceHermesLite.dll
LoadedModule[76]=C:\WINDOWS\SYSTEM32\IPHLPAPI.DLL
LoadedModule[77]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceICOM.dll
LoadedModule[78]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceLime.dll
LoadedModule[79]=C:\Program Files\SDR-Radio.com (V3)\LimeSuite.dll
LoadedModule[80]=C:\WINDOWS\SYSTEM32\MSVCP120.dll
LoadedModule[81]=C:\WINDOWS\SYSTEM32\D2D1.dll
LoadedModule[82]=C:\WINDOWS\SYSTEM32\DWrite.dll
LoadedModule[83]=C:\WINDOWS\system32\windowscodecs.dll
LoadedModule[84]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceNetSDR.dll
LoadedModule[85]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceOpenHPSDR.dll
LoadedModule[86]=C:\Program Files\SDR-Radio.com (V3)\SDRSourcePerseus.dll
LoadedModule[87]=C:\Program Files\SDR-Radio.com (V3)\SDRSourcePluto.dll
LoadedModule[88]=C:\Program Files\SDR-Radio.com (V3)\libad9361.dll
LoadedModule[89]=C:\Program Files\SDR-Radio.com (V3)\libiio.dll
LoadedModule[90]=C:\Program Files\SDR-Radio.com (V3)\libserialport-0.dll
LoadedModule[91]=C:\Program Files\SDR-Radio.com (V3)\libxml2.dll
LoadedModule[92]=C:\WINDOWS\SYSTEM32\WSOCK32.dll
LoadedModule[93]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceRTL2832U.dll
LoadedModule[94]=C:\Program Files\SDR-Radio.com (V3)\rtlsdr.dll
LoadedModule[95]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceRTLSDR.dll
LoadedModule[96]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceRX666.dll
LoadedModule[97]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceRX888.dll
LoadedModule[98]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceSDRIQ.dll
LoadedModule[99]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceSDRplay.dll
LoadedModule[100]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceSDRplayV3.dll
LoadedModule[101]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceServer.dll
LoadedModule[102]=C:\WINDOWS\SYSTEM32\WININET.dll
LoadedModule[103]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceSoftRockSi570.dll
LoadedModule[104]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceSoftRockXTAL.dll
LoadedModule[105]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceSpectranRawIQ.dll
LoadedModule[106]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceSpectranRTSA.dll
LoadedModule[107]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceStreamer.dll
LoadedModule[108]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceWinradioG31DDC.dll
LoadedModule[109]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceWinradioG33DDC.dll
LoadedModule[110]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceWinradioG35DDC.dll
LoadedModule[111]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceWinradioG39DDC.dll
LoadedModule[112]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceWinradioG69DDC.dll
LoadedModule[113]=C:\Program Files\SDR-Radio.com (V3)\SDRSourceWinradioSigma.dll
LoadedModule[114]=C:\WINDOWS\system32\napinsp.dll
LoadedModule[115]=C:\WINDOWS\system32\pnrpnsp.dll
LoadedModule[116]=C:\WINDOWS\System32\mswsock.dll
LoadedModule[117]=C:\WINDOWS\SYSTEM32\DNSAPI.dll
LoadedModule[118]=C:\WINDOWS\System32\NSI.dll
LoadedModule[119]=C:\WINDOWS\System32\winrnr.dll
LoadedModule[120]=C:\WINDOWS\system32\wshbth.dll
LoadedModule[121]=C:\WINDOWS\system32\nlansp_c.dll
LoadedModule[122]=C:\WINDOWS\System32\fwpuclnt.dll
LoadedModule[123]=C:\Windows\System32\rasadhlp.dll
LoadedModule[124]=C:\WINDOWS\SYSTEM32\bcrypt.dll
LoadedModule[125]=C:\WINDOWS\system32\hnetcfg.dll
LoadedModule[126]=C:\WINDOWS\system32\USERENV.dll
LoadedModule[127]=C:\WINDOWS\system32\GPAPI.dll
LoadedModule[128]=C:\WINDOWS\System32\npmproxy.dll
LoadedModule[129]=C:\WINDOWS\system32\upnp.dll
LoadedModule[130]=C:\WINDOWS\system32\WINHTTP.dll
LoadedModule[131]=C:\WINDOWS\system32\SSDPAPI.dll
LoadedModule[132]=C:\WINDOWS\system32\urlmon.dll
LoadedModule[133]=C:\WINDOWS\system32\iertutil.dll
LoadedModule[134]=C:\WINDOWS\system32\srvcli.dll
LoadedModule[135]=C:\WINDOWS\system32\netutils.dll
LoadedModule[136]=C:\WINDOWS\SYSTEM32\sxs.dll
LoadedModule[137]=C:\WINDOWS\SYSTEM32\dhcpcsvc.DLL
LoadedModule[138]=C:\WINDOWS\system32\webio.dll
LoadedModule[139]=C:\WINDOWS\SYSTEM32\WINNSI.DLL
LoadedModule[140]=C:\WINDOWS\system32\SspiCli.dll
LoadedModule[141]=C:\WINDOWS\SYSTEM32\dhcpcsvc6.DLL
LoadedModule[142]=C:\WINDOWS\System32\netshell.dll
LoadedModule[143]=C:\WINDOWS\System32\NetSetupApi.dll
LoadedModule[144]=C:\WINDOWS\system32\wkscli.dll
LoadedModule[145]=C:\WINDOWS\SYSTEM32\dsound.dll
LoadedModule[146]=C:\WINDOWS\SYSTEM32\ResampleDmo.DLL
LoadedModule[147]=C:\WINDOWS\SYSTEM32\powrprof.dll
LoadedModule[148]=C:\WINDOWS\SYSTEM32\winmmbase.dll
LoadedModule[149]=C:\WINDOWS\SYSTEM32\msdmo.dll
LoadedModule[150]=C:\WINDOWS\SYSTEM32\UMPDC.dll
LoadedModule[151]=C:\WINDOWS\System32\MMDevApi.dll
LoadedModule[152]=C:\WINDOWS\System32\DEVOBJ.dll
LoadedModule[153]=C:\WINDOWS\SYSTEM32\wdmaud.drv
LoadedModule[154]=C:\WINDOWS\SYSTEM32\ksuser.dll
LoadedModule[155]=C:\WINDOWS\SYSTEM32\AVRT.dll
LoadedModule[156]=C:\WINDOWS\SYSTEM32\AUDIOSES.DLL
LoadedModule[157]=C:\WINDOWS\SYSTEM32\msacm32.drv
LoadedModule[158]=C:\WINDOWS\SYSTEM32\MSACM32.dll
LoadedModule[159]=C:\WINDOWS\SYSTEM32\midimap.dll
LoadedModule[160]=C:\WINDOWS\System32\WINTRUST.dll
LoadedModule[161]=C:\WINDOWS\System32\CRYPT32.dll
LoadedModule[162]=C:\WINDOWS\SYSTEM32\MSASN1.dll
LoadedModule[163]=C:\Program Files\SDR-Radio.com (V3)\ExtIOmc_ELAD_FDMDUO.dll
State[0].Key=Transport.DoneStage1
State[0].Value=1
OsInfo[0].Key=vermaj
OsInfo[0].Value=10
OsInfo[1].Key=vermin
OsInfo[1].Value=0
OsInfo[2].Key=verbld
OsInfo[2].Value=22000
OsInfo[3].Key=ubr
OsInfo[3].Value=2538
OsInfo[4].Key=versp
OsInfo[4].Value=0
OsInfo[5].Key=arch
OsInfo[5].Value=9
OsInfo[6].Key=lcid
OsInfo[6].Value=3081
OsInfo[7].Key=geoid
OsInfo[7].Value=12
OsInfo[8].Key=sku
OsInfo[8].Value=48
OsInfo[9].Key=domain
OsInfo[9].Value=0
OsInfo[10].Key=prodsuite
OsInfo[10].Value=256
OsInfo[11].Key=ntprodtype
OsInfo[11].Value=1
OsInfo[12].Key=platid
OsInfo[12].Value=10
OsInfo[13].Key=sr
OsInfo[13].Value=0
OsInfo[14].Key=tmsi
OsInfo[14].Value=222371501
OsInfo[15].Key=osinsty
OsInfo[15].Value=1
OsInfo[16].Key=iever
OsInfo[16].Value=11.1.22000.0-11.0.1000
OsInfo[17].Key=portos
OsInfo[17].Value=0
OsInfo[18].Key=ram
OsInfo[18].Value=7592
OsInfo[19].Key=svolsz
OsInfo[19].Value=237
OsInfo[20].Key=wimbt
OsInfo[20].Value=0
OsInfo[21].Key=blddt
OsInfo[21].Value=210604
OsInfo[22].Key=bldtm
OsInfo[22].Value=1628
OsInfo[23].Key=bldbrch
OsInfo[23].Value=co_release
OsInfo[24].Key=bldchk
OsInfo[24].Value=0
OsInfo[25].Key=wpvermaj
OsInfo[25].Value=0
OsInfo[26].Key=wpvermin
OsInfo[26].Value=0
OsInfo[27].Key=wpbuildmaj
OsInfo[27].Value=0
OsInfo[28].Key=wpbuildmin
OsInfo[28].Value=0
OsInfo[29].Key=osver
OsInfo[29].Value=10.0.22000.2538.amd64fre.co_release.210604-1628
OsInfo[30].Key=buildflightid
OsInfo[31].Key=edition
OsInfo[31].Value=Professional
OsInfo[32].Key=ring
OsInfo[32].Value=Retail
OsInfo[33].Key=expid
OsInfo[33].Value=FX:117B9872,FX:11C6E5C2,FX:11CC111C,FX:11DE1DCB,FX:11DF5B12,FX:11DF5B75,FX:1231F3B5,FX:123DAFA1,FX:124F14AD,FX:125085E1,FX:125A7FB9,FX:12613B8D,FX:1263CF81,FX:1264FA81,FX:126AF454,FX:1272123C,FX:127432DD,FX:127C936C,FX:127DBFC2,FX:12816BC3,FX:1283FFFD,FX:128407EE,FX:128571F8,FX:12865419,FX:1286546D,FX:12913A36,FX:1294146B,FX:12A6D99B,FX:12A74DD7
OsInfo[34].Key=fconid
OsInfo[34].Value=18299130,0,2,0;19638787,0,2,0;23531064,2,2,0;23562335,2,2,0;23563673,2,2,0;24172318,0,2,1;25704915,1,2,0;27336672,0,1,1;32862274,0,2,0;34508795,0,2,0;35825666,0,1,0;37474955,0,1,0;37609034,0,1,0;37801696,0,1,0;37837060,0,1,0;37926348,0,1,0;38406949,0,1,0;38651681,0,1,0;39263329,1,2,0;39319950,0,2,0;39545181,1,2,0;39645403,0,1,0;39909691,0,2,1;40025975,0,1,0;40325239,0,1,0;40741162,0,2,1;40984526,0,1,0;40997837,0,1,1;41172767,0,1,0;41217122,0,2,1;41342071,0,1,0;42052423,0,2,0;42621370,0,2,1;42676171,0,2,1;42870786,0,2,1;43754025,0,2,1;43882373,0,2,1;44047927,0,2,1;44171630,0,2,1;44173337,0,1,0;44191982,0,2,1;44255354,0,2,1;44309843,0,2,1;44310074,0,2,1;44469385,0,2,1;44595946,0,2,1;44608279,0,2,1;44612805,0,2,1;44757028,0,2,1;44770519,0,2,1;44784664,0,2,1;44889433,0,2,1;44970661,0,2,1;44976542,0,2,1;44986715,0,2,1;44986778,0,2,1;44986802,0,2,1;44987689,0,2,1;45026700,0,2,1;45047952,0,2,1;45048083,0,2,1;45113578,0,2,1;45121754,0,2,1;45126150,0,2,1;45185354,0,2,1;45231502,0,2,1;45233630,0,2,1;45250404,0,2,1;45250511,0,2,1;45276658,0,2,1;45279760,0,2,1;45416041,0,2,1;46077170,0,2,1;46570133,0,2,1;46613606,0,2,1
OsInfo[35].Key=containerid
OsInfo[36].Key=containertype
OsInfo[37].Key=edu
OsInfo[37].Value=0
OsInfo[38].Key=servicinginprogress
OsInfo[38].Value=0
FriendlyEventName=Stopped working
ConsentKey=BEX64
AppName=SDR Server service (V3)
AppPath=C:\Program Files\SDR-Radio.com (V3)\SDRServerService.exe
NsPartner=windows
NsGroup=windows8
ApplicationIdentity=C7032A1CEAA6A2A051B6DB5525664700
MetadataHash=23619970601:32:14.996: Select Radio> Stopping: stop reader thread
