RSP1A not starting
Posted: Fri Jan 12, 2024 3:20 am
so I went the cheap way, because this is what I could afford. I bought a clone RSP1A from Aliexpress.
It works fine with SDRConnect.
Does not start with SDRUno no matter which version, albeit it starts right after installation, but not if I restart the program.
In SDRConsole it won't start no matter which API pair I use. According to logfile the cause is:
sdrplay_api_SelectDevice failed: sdrplay_api_FailedVerification5
I'm pretty sure it is because of the serial number does not match with sdrplay database.
Is there any workaround for this or I just bought an expensive paperweight?
Attached is the logfile.
I tried API 3.06, 3.07, 3.08 and 3.09 with respective .dll files available on SDRC website.
Please be kind, I'm new to this SDR stuff
