sdrconsole with different tx and rx
Posted: Sat Feb 24, 2024 12:00 pm
by remis
Hello all.
Is it possible to run sdrconle with adalm pluto on TX and rtl sdr key for rx?
73's
Re: sdrconsole with different tx and rx
Posted: Sat Feb 24, 2024 2:01 pm
remis wrote: ↑Sat Feb 24, 2024 12:00 pm
Hello all.
73's
Not possible running one instance. You would need two instances of SDRC, one for the RTL and one for the Pluto. Then it could be done, yes, but frequency control would be totally independent of each other.
I'm not sure if anyone has tried to sync two instances of SDRC together via com ports. In theory I think that may be possible although pretty sure it would need two identities to keep the com port settings separate. Then of course you would need to sort out the antenna switching and PTT to mute the receiver. I guess the RX could be left to auto-mute. Goes without saying you'd need to be careful not to blow the RTL with excessive RF. I'm sure you already thought about this.
Identities:
https://www.sdr-radio.com/starting#Identity
Auto-Mute:
https://www.sdr-radio.com/wideband-dsp
Pluto (I think?) capable of full duplex ... the Pluto?
https://www.sdr-radio.com/Pluto-transmit
Posted: Sat Feb 24, 2024 6:21 pm
by remis
Hi Max
Tnx for answering. I will test two instances.
All for QO-100 sat, one instance for Tx ( pluto ) and another for rx ( rtl sdr ). And how all work.
73's
Rémi
Posted: Sat Feb 24, 2024 8:22 pm
remis wrote: ↑Sat Feb 24, 2024 6:21 pm
Hi Max
73's
Rémi
Hi Remi
Just for my own interest, any reason why you do not just use Pluto as transceiver?
https://www.sdr-radio.com/g4elis-qo-100-station
https://youtu.be/CwMfEAJfsZk
Posted: Sun Feb 25, 2024 5:20 pm
by remis
Hi Max
I see that i have better rx with my rtl sdr key, and want you try it just for curiosity. And for the final compare the two rx system.
73's
Rémi
Posted: Sun Feb 25, 2024 10:32 pm
remis wrote: ↑Sun Feb 25, 2024 5:20 pm
Hi Max
73's
Rémi
Ah, OK. Understood.
