SDRconsole frequency data export
LuNe
Unread post by LuNe »
I am using sdrconsole for the QO100 operation successfully.
I have linked my external radio and the SDR console shares the frequency information on 70cm to my rig.
On the SDR display I see the 10.489 frequency as it is used on the satellite.
How can I read this frequency on my logbook? Is there any USB port or com port to connect to a logbook programm?
Omnirig shows the frequency on 70cm which I do not want for the logbook entry!?
Thanky for your help
Lutz DL9DAN
Re: SDRconsole frequency data export
LuNe wrote: Thu Apr 04, 2024 3:42 pm Hello,
Lutz DL9DAN
I don't fully understand Omnirig operation. However, most logging programs offer different interfaces (Hamlib for example) or direct com port link.
If it were me, I would keep Omnirig for the external rig, set up virtual com ports (I use and recommend VSP Manager from K5FR as being trouble-free with SDRC) and then use those virtual com ports to interface with the logging program (not Omnirig obviously).
For more CAT/VSP information see here:
LuNe
Hi Max,
of course I am using VSPE for my other applications and connections - but:
for my QO100 (FT817 on Microham USB III) I use Omnirig for the CAT to the TRX (external radio) - this is fine
But for the RX I have the RSP2pro which is driven by the sdrconsole and the sdrconsole is set to the correct frequency using the offset.
Now how can I get this frequency out of this connection??
My log programm does not offer an offset, if I connect to the omnirig interface(ext radio frequency ) it would log 438.020e.g. which is not sufficient.
I want to read the 10.489 out of this construction . . .
73 Lutz
LuNe wrote: Thu Apr 04, 2024 7:46 pm But for the RX I have the RSP2pro which is driven by the sdrconsole and the sdrconsole is set to the correct frequency using the offset.
73 Lutz
Sorry Lutz, not sure of the answer. Omnirig I am sure cannot output this information. From what I can see, to log QO-100 people are using transverter offsets in the logging program. Log4OM for example has "Sat Mode":
https://forum.amsat-dl.org/cms/index.ph ... 100-1-pdf/
Hopefully some QO-100 operators will be along to say how they manage the situation. Good luck.
73, Max
