Pluto Plus SDR option to add with Fixed IP Option !!!
rasp123
Unread post by rasp123 »
On SDR-Console V 3.3 when I try to select Hermes Lite 2 in the Search option, I am given the below option
-> Default
-> Extended
-> Fixed Address
But when I select the option of PlutoSDR in the search option,I do not find any of the options listed above & as I am connected through VPN, it says nothing found, Sorry !
For Hermes Lite 2 although not discovered in the search, by using the "Fixed Address" option, i am able to connect to the HL2 through the VPN.
It will be great if we can have the same option for Pluto plus SDR.
Ravi
