SerialPort CAT issues with MD (current mode) command ? (Also SM / Signal Meter level & MU Audio Mute status commands)
aportela
Unread post by aportela »
I'm developing a device to remote control the console and I observed an anomally with the MD command using the Serial port (CAT) connection.
As the documentation say (https://www.sdr-radio.com/SerialPort):
MD
Mode
Read: MD; returns the current mode.
Write MD<mode>;
Note: the mode value only supports a single digit.
Values:
0 DSB
1 LSB
2 USB
3 CW (upper sideband)
4 FM
5 SAM (synchronous AM, includes ECSS)
6 Not used
7 CW (lower sideband)
8 Wide FM
9 Broadcast FM
If I set the console on BFM (Broadcast FM), N-FM (Narrow FM) or W-FM (Wide FM) every response received from "MD;" command is "MD4;" (values ​​"MD8;" or "MD9;" are never returned). Another modes (USB/LSB/CW...) are working OK.
Am I doing something wrong or is this a bug ?
aportela
Re: SerialPort CAT issues with MD (current mode) command ?
To provide more information, sending the commands (from my software) to change the mode ("MD4;", "MD8;", "MD9;") works fine (I mean, changes the NFM/WFM/BFM mode correctly in the sdr-radio console), the problem only affects the reception of the current mode when it is an FM variant
aportela
Now I am testing with the SM command; (signal level meter) and I get the impression that the result returned is less than the one shown in the SDRRadio console. According to the documentation, the value corresponds to:
Signal meter level
Read: SM; returns the signal level as a four-digit value in 3dB steps (one S-unit is 6dB):
S0 = 0 units
S5 = 10 units
S9 - 18 units.
Below is a table with what I understand to be the equivalences:
SMdBSignal
00000S0
00013S0.5
00026S1
00039S1.5
000412S2
000515S2.5
000618S3
000721S3.5
000824S4
000927S4.5
001030S5
001133S5.5
001236S6
001339S6.5
001442S7
001545S7.5
001648S8
001751S8.5
001854S9
001957S9+3 dB
002060S9+6 dB
002163S9+9 dB
002266S9+12 dB
002369S9+15 dB
002472S9+18 dB
002575S9+21 dB
002678S9+24 dB
002781S9+27 dB
002884S9+30 dB
002987S9+33 dB
003090S9+36 dB
003193S9+39 dB
003296S9+42 dB
003399S9+45 dB
0034102S9+48 dB
0035105S9+51 dB
0036108S9+54 dB
0037111S9+57 dB
0038114S9+60 dB
My problem is that in the SDR-Radio console I see a signal (S3) but when sending the SM command; I repeatedly receive responses:
SM00004;
SM00004;
SM00004;
SM00005;
SM00004;
Which gives the impression of being one less unit (near to S2)
I have tried other signals with different values ​​and the SDRRadio console always seems to show a value greater than the one returned by the TS-2000's CAT protocol.
I don't know if I'm missing something and I'm making a mistake or is it a bug?
aportela
Re: SerialPort CAT issues with MD (current mode) command ? (Also SM / Signal Meter level command)
I think I found another issue, the MU (Audio mute status) command does not return a value, the documentation says:
MU
Audio mute status, 0 (muted) or 1 (not muted).
Read: MU; returns either 0 (muted) or 1 (not muted).
Write: MU<status>;
Sending the command "MU0;" or "MU1;" it swaps the mute value in the console correctly but if I send "MU;" to get the status, I get nothing
I am carrying out all these tests directly with the putty software by opening a serial console to the COM port directly and sending the commands, so it does not seem possible that it is due to a bug in the software that I am implementing
aportela
aportela wrote: Wed Jun 12, 2024 10:41 pm Now I am testing with the SM command; (signal level meter) and I get the impression that the result returned is less than the one shown in the SDRRadio console. According to the documentation, the value corresponds to:
Signal meter level
S0 = 0 units
S5 = 10 units
S9 - 18 units.
SMdBSignal
00000S0
00013S0.5
00026S1
00039S1.5
000412S2
000515S2.5
000618S3
000721S3.5
000824S4
000927S4.5
001030S5
001133S5.5
001236S6
001339S6.5
001442S7
001545S7.5
001648S8
001751S8.5
001854S9
001957S9+3 dB
002060S9+6 dB
002163S9+9 dB
002266S9+12 dB
002369S9+15 dB
002472S9+18 dB
002575S9+21 dB
002678S9+24 dB
002781S9+27 dB
002884S9+30 dB
002987S9+33 dB
003090S9+36 dB
003193S9+39 dB
003296S9+42 dB
003399S9+45 dB
0034102S9+48 dB
0035105S9+51 dB
0036108S9+54 dB
0037111S9+57 dB
0038114S9+60 dB
SM00004;
SM00004;
SM00004;
SM00005;
SM00004;
After more testings & debugging on data received from serial I found that on SDR Console the representation of signal meter widget the value is also incorrect, I mean: take a look to this screenshot:
On the widget, the yellow label value is "S8" but the Smeter "analog" bar is pointing below S7
