I'm developing a device to remote control the console and I observed an anomally with the MD command using the Serial port (CAT) connection.
As the documentation say (https://www.sdr-radio.com/SerialPort):
MD
Mode
Read: MD; returns the current mode.
Write MD<mode>;
Note: the mode value only supports a single digit.
Values:
0 DSB
1 LSB
2 USB
3 CW (upper sideband)
4 FM
5 SAM (synchronous AM, includes ECSS)
6 Not used
7 CW (lower sideband)
8 Wide FM
9 Broadcast FM
If I set the console on BFM (Broadcast FM), N-FM (Narrow FM) or W-FM (Wide FM) every response received from "MD;" command is "MD4;" (values "MD8;" or "MD9;" are never returned). Another modes (USB/LSB/CW...) are working OK.
Am I doing something wrong or is this a bug ?
SerialPort CAT issues with MD (current mode) command ? (Also SM / Signal Meter level & MU Audio Mute status commands)
Re: SerialPort CAT issues with MD (current mode) command ?
To provide more information, sending the commands (from my software) to change the mode ("MD4;", "MD8;", "MD9;") works fine (I mean, changes the NFM/WFM/BFM mode correctly in the sdr-radio console), the problem only affects the reception of the current mode when it is an FM variant
Now I am testing with the SM command; (signal level meter) and I get the impression that the result returned is less than the one shown in the SDRRadio console. According to the documentation, the value corresponds to:
Signal meter level
Read: SM; returns the signal level as a four-digit value in 3dB steps (one S-unit is 6dB):
S0 = 0 units
S5 = 10 units
S9 - 18 units.
Below is a table with what I understand to be the equivalences:
My problem is that in the SDR-Radio console I see a signal (S3) but when sending the SM command; I repeatedly receive responses:
SM00004;
SM00004;
SM00004;
SM00005;
SM00004;
Which gives the impression of being one less unit (near to S2)
I have tried other signals with different values and the SDRRadio console always seems to show a value greater than the one returned by the TS-2000's CAT protocol.
I don't know if I'm missing something and I'm making a mistake or is it a bug?
Signal meter level
S0 = 0 units
S5 = 10 units
S9 - 18 units.
SM | dB | Signal |
0000 | 0 | S0 |
0001 | 3 | S0.5 |
0002 | 6 | S1 |
0003 | 9 | S1.5 |
0004 | 12 | S2 |
0005 | 15 | S2.5 |
0006 | 18 | S3 |
0007 | 21 | S3.5 |
0008 | 24 | S4 |
0009 | 27 | S4.5 |
0010 | 30 | S5 |
0011 | 33 | S5.5 |
0012 | 36 | S6 |
0013 | 39 | S6.5 |
0014 | 42 | S7 |
0015 | 45 | S7.5 |
0016 | 48 | S8 |
0017 | 51 | S8.5 |
0018 | 54 | S9 |
0019 | 57 | S9+3 dB |
0020 | 60 | S9+6 dB |
0021 | 63 | S9+9 dB |
0022 | 66 | S9+12 dB |
0023 | 69 | S9+15 dB |
0024 | 72 | S9+18 dB |
0025 | 75 | S9+21 dB |
0026 | 78 | S9+24 dB |
0027 | 81 | S9+27 dB |
0028 | 84 | S9+30 dB |
0029 | 87 | S9+33 dB |
0030 | 90 | S9+36 dB |
0031 | 93 | S9+39 dB |
0032 | 96 | S9+42 dB |
0033 | 99 | S9+45 dB |
0034 | 102 | S9+48 dB |
0035 | 105 | S9+51 dB |
0036 | 108 | S9+54 dB |
0037 | 111 | S9+57 dB |
0038 | 114 | S9+60 dB |
SM00004;
SM00004;
SM00004;
SM00005;
SM00004;
Re: SerialPort CAT issues with MD (current mode) command ? (Also SM / Signal Meter level command)
I think I found another issue, the MU (Audio mute status) command does not return a value, the documentation says:
MU
Audio mute status, 0 (muted) or 1 (not muted).
Read: MU; returns either 0 (muted) or 1 (not muted).
Write: MU<status>;
Sending the command "MU0;" or "MU1;" it swaps the mute value in the console correctly but if I send "MU;" to get the status, I get nothing
I am carrying out all these tests directly with the putty software by opening a serial console to the COM port directly and sending the commands, so it does not seem possible that it is due to a bug in the software that I am implementing
MU
Write: MU<status>;
Re: SerialPort CAT issues with MD (current mode) command ? (Also SM / Signal Meter level & MU Audio Mute status commands
Sounds like a Simon bug.
aportela wrote: ↑Wed Jun 12, 2024 10:41 pm Now I am testing with the SM command; (signal level meter) and I get the impression that the result returned is less than the one shown in the SDRRadio console. According to the documentation, the value corresponds to:
Signal meter level
S0 = 0 units
S5 = 10 units
S9 - 18 units.
SM dB Signal 0000 0 S0 0001 3 S0.5 0002 6 S1 0003 9 S1.5 0004 12 S2 0005 15 S2.5 0006 18 S3 0007 21 S3.5 0008 24 S4 0009 27 S4.5 0010 30 S5 0011 33 S5.5 0012 36 S6 0013 39 S6.5 0014 42 S7 0015 45 S7.5 0016 48 S8 0017 51 S8.5 0018 54 S9 0019 57 S9+3 dB 0020 60 S9+6 dB 0021 63 S9+9 dB 0022 66 S9+12 dB 0023 69 S9+15 dB 0024 72 S9+18 dB 0025 75 S9+21 dB 0026 78 S9+24 dB 0027 81 S9+27 dB 0028 84 S9+30 dB 0029 87 S9+33 dB 0030 90 S9+36 dB 0031 93 S9+39 dB 0032 96 S9+42 dB 0033 99 S9+45 dB 0034 102 S9+48 dB 0035 105 S9+51 dB 0036 108 S9+54 dB 0037 111 S9+57 dB 0038 114 S9+60 dB
SM00004;
SM00004;
SM00004;
SM00005;
SM00004;
After more testings & debugging on data received from serial I found that on SDR Console the representation of signal meter widget the value is also incorrect, I mean: take a look to this screenshot:
On the widget, the yellow label value is "S8" but the Smeter "analog" bar is pointing below S7
