Hi all.
Has anyone had any trouble with the SpyServer on later (the latest) revisions of SDRC?
I had prepared two RSP3, one with a RTL-Dongle and one with a AirSpyHF+ (two connector version) say ~a year ago and they both worked fine then.
I have not put them into service (been waiting for my fiber to be installed at my EME/summer QTH...puh), but now I was about to make use of them.
Unfortunately, none of them are found by SDRC v3.0.26 The Ethernet link seems to work, but SDRC is not satisfied with the answers from the SpyServer.
I start here with this question and maybe I can provide logs later if that would be of any help to understand the problem.
73 / Ingolf, SM6FHZ
Later revisions of SDRC and SpyServer
Re: Later revisions of SDRC and SpyServer
Logs would help. If you send me the IP address, username/password I'll try myself.
Thanks Simon.
The SpyServers are only local in my LAN. Not even that now, only local to one Laptop.
Slept on it, I came to realize that the RSP3 for the RTL-Dongle was used as a RTL TCP device. Doing that it came to life. So, that one is solved. Even if I am curious about why it does not work being searched for as a SpyServer. But it is fine for now.
For the other RSP3 SpyServer for the AirSpy HF+, I will do some more trials. If not successful I will report back here with a log etc.
73 / Ingolf, SM6FHZ
73 / Ingolf, SM6FHZ
Dear Simon.
Got it working again. Unfortunately, I was not able to 100% track the problem down. It seemed to be related to the set-up of the Ethernet communication of the RSP3, but I am not sure exactly what the cure was. Spooky....
No problem with the SDRC. Operator induced error, I presume.
I will set it up in it's real environment and start using it. I hope it will stay healthy.
73 / Ingolf, SM6FHZ
73 / Ingolf, SM6FHZ
