Loading ExtIOmc
Moderator: NN4F
Loading ExtIOmc
The ELAD library loads the ExtIOmc DLL using the default Windows search path using the LoadLibrary function. Sometimes this isn't always as reliable as it should be as the search path can be altered using the SetDllDirectory function, so the code used in SDR Console is modified to only look for the support DLL in the folder containing SDR Console.exe.
