KA1GJU Super Station #3 Now MUCH improved!
Posted: Mon Nov 09, 2020 10:32 pm
Apparently I had the wrong antenna for the last several months! Now on the proper one as published (51' EFW in a vertical configuration with a 9:1 and good ground.)
I have numerous coax's entering the room where the server is located, all leading to basement where some go back up to attic, some go outside via buried conduit to the tree line 150' away.
WRMI 9395 kHz TXR is offline for repairs, so the oldies music has moved up to 9455 kHz, Pink Floyd, Money is playing!
Give it some use and let me know how it works for you. Laptop is an old W7 Acer Netbook, 32 bit machine.
