New to SDR-Console.
Using FDM-Duo.
The RX is fine but I can not transmit. I use a foot pedal and I CAN key the ptt but I can not get my usb mic audio connected, also I can not choose any transmit options, the transmit pane is greyed out.
Any help?
Can not xmit
Moderator: NN4F
Re: Can not xmit
Screenshots - let's see what you've done.
Re: Can not xmit
Please post here, saves me a lot of time digging around.
Re: Can not xmit
I have most of my issue resolved. The exceptions are as follows;
My issues now:
(1) I do not see the options tab that is specific to the duo.
(2) I can not select mode (usb, lsb, etc.), I can click the buttons but nothing happens.
My issues now:
Re: Can not xmit
The mode buttons in rx pane do not change the xmit mode. even if i click sync rx. They DO change the receieve mode (in console) but not xmit.
Re: Can not xmit
I am trying to respond but I dont see my messages.
The Mode select buttons only work on RX, they do not change mode on the radio.
Re: Can not xmit
I have set up SDR Console exactly as described on https://www.sdr-radio.com/elad-transceiver , however, when clicking on the Tune button on the docked TX pane the Elad goes into TX but there is absolutely no power out? FDM-DUO Audio v1.04 has NOT been selected as the default output device. What am I missing? As always, your help is greatly appreciated.
Re: Can not xmit
NE7EE wrote: ↑Tue Nov 17, 2020 1:21 am I have set up SDR Console exactly as described on https://www.sdr-radio.com/elad-transceiver , however, when clicking on the Tune button on the docked TX pane the Elad goes into TX but there is absolutely no power out? FDM-DUO Audio v1.04 has NOT been selected as the default output device. What am I missing? As always, your help is greatly appreciated.
Please post a screenshot! You do not select FDM-DUO Audio v1.04, this is done for you.
Re: Can not xmit
Please see my settings in this google docs link:
https://docs.google.com/document/d/17sf ... sp=sharing
Christoph
Christoph
