SDR Server Not being recognized by SDR Space V3
Posted: Wed Dec 09, 2020 5:58 pm
Greetings-
I have SDR Server 3.0.25 running at our club base station serving a SDR Play RSP1A. The system is fully functional on the LAN.
Remote access is possible with SDR Console from the outside world (internet) with the radio definition being manually configured to the IP address and port. Operates well.
Enabling "On Air" does not allow V3 to recognize the station, or select/connect from the list of servers when browsing the list. The site annunciate's the "WB2ELW Cannot access 72.75.225.32 port 50101 ..." message.
I have included a snippet of the log file below. Note at 2020-12-09 12:29:27, OnAir> On-Air Sent 493 bytes to 81.174.138.141:50199 and
2020-12-09 12:29:37, OnAir> On-Air Reading failed, COnAirConnection::SelectRead(), Select error, timeout after 10 seconds
Port 50101 is enabled and open to the internet as I can access remotely from Console. Port scan verifies.
LAN DNS is also operational., but just as a check, I replaced the On Air Server address with the IP 81.174.138.141 just as a check. Same result.
It looks like Console (with manual IP configured) can access Server, but sdrserver.com cannot. Please advise.
Thank you,
Mike KB2FX
<SDRRadioV3 xml:lang="EN"><OnAir upload_code="WelcomeV3"><format>1.0</format><name>WB2ELW</name><address></address><port>50101</port><lat></lat><lon></lon><homepage></homepage><antenna></antenna><location></location><comment></comment><version>Version 3.0.25 build 2012</version><default_password></default_password><default_username></default_username><Instance><Recording>0</Recording><Radio>SDR-IQ, SDRPlay RSP1A</Radio><Bandwidth></Bandwidth><Frequency></Frequency><Index>Idle</Index><TimeOn></TimeOn><Mode></Mode><Time></Time><UserName></UserName><UserAddress></UserAddress><UserLocation></UserLocation></Instance></OnAir></SDRRadioV3>
2020-12-09 12:29:27, OnAir> On-Air Data ............: 0A-44-40-38-E6-91-8E-5B...
2020-12-09 12:29:27, OnAir> On-Air Size (bytes) ....: 665
2020-12-09 12:29:27, OnAir> On-Air Compress flags ..: 5
2020-12-09 12:29:27, OnAir> On-Air Compressed ......: 481
2020-12-09 12:29:27, OnAir> On-Air Update index ....: 0
2020-12-09 12:29:27, OnAir> On-Air Connecting to 81.174.138.141:50199, status = OK
2020-12-09 12:29:27, OnAir> On-Air Socket option TCP_NODELAY ...: 1
2020-12-09 12:29:27, OnAir> On-Air SO_RCVBUF .....: 1048576
2020-12-09 12:29:27, OnAir> On-Air SO_SNDBUF .....: 1048576
2020-12-09 12:29:27, OnAir> On-Air SO_RCVTIMEO ...: 5000 (milliseconds)
2020-12-09 12:29:27, OnAir> On-Air SO_SNDTIMEO ...: 5000 (milliseconds)
2020-12-09 12:29:27, OnAir> On-Air -
2020-12-09 12:29:37, OnAir> Address: 81.174.138.141
2020-12-09 12:29:37, OnAir> Port: 50199
2020-12-09 12:29:37, OnAir> XML: <?xml version="1.0"?>
Thank you,
Mike KB2FX
