SDR Console and VNC
Posted: Thu Dec 17, 2020 6:48 pm
by pavolg
I use SDR Console on a laptop with Win10. I often put it outside on the garden and I connect to it through RealVNC. When I close the laptop, connect to it using VNC and run SDR Console, it looks like this - no FFT, waterfall, some buttons...:
If the laptop is opened, everything is fine. Could you help me?
I also tried TeamViewer - it's the same.
I tested it also on my older notebook (Win7) with same versions (latest) and same settings of VNC and SDR Console - it works without any problems.
Re: SDR Console and VNC
Posted: Thu Dec 17, 2020 7:29 pm
Looks very much as though VNC / RealVNC doesn't like Direct2D (DirectX) windows. Myself I use Windows Remote Desktop.
Why not use the server?
Posted: Thu Dec 17, 2020 9:10 pm
by G0OFE
Anydesk is also good.
I use it when checking in from work as the server doesnt get trough the work hifi firewall.
Posted: Fri Dec 18, 2020 10:25 am
by pavolg
I have "DirectX" option turned off in VNC settings. And I have the same problem with TeamViewer. Other software (e.g. SDR#) works well. So, it looks like the problem only with SDR Console.
I use SDR mainly to decode data from radiosondes or planes. Everything is running on one computer - SDR Console, decoder etc. I only want to check it from time to time. I often use a mobile phone or PC with Linux to connect to laptop with running SDR. WRD or Server connection isn't good options for me.
Posted: Fri Dec 18, 2020 1:11 pm
pavolg wrote: ↑Fri Dec 18, 2020 10:25 am
