DSDplus N-FM/W-FM question
Posted: Mon Jan 25, 2021 7:16 pm
by Barry WB2ZXJ
I've been playing with DSDplus and have noticed that I have to use W-FM instead of N-FM in order to decode DMR transmissions.
W-FM works (with some sync errors), N-FM never syncs.
I have a question on the horizontal bar graph showing audio levels in the Receive DSP panel. What do the two bars indicate?
One is signal, the other is? Also, switching from N-FM to W-FM causes the bars to go red (I must be over driving something).
See attached. Note: the two screenshots show idle time between transmissions.
Re: DSDplus N-FM/W-FM question
Posted: Mon Jan 25, 2021 7:57 pm
Hi Barry
See here for NFM versus WFM with DSD+:
https://www.sdr-radio.com/dsdplus
Seems is the need to have no de-emphasis or filters etc. WFM is "clean", so to speak. I believe it is similar issue in other software like SDR#:
Posted: Mon Jan 25, 2021 8:54 pm
by Barry WB2ZXJ
Thanks Max,
I don't know how I missed that.
I see Simon explains that the volume widget is Red when above 95%.
Still haven't found out why there are two bars.
Barry
WB2ZXJ
Posted: Tue Jan 26, 2021 12:57 am
No idea on that Barry, but as it's flat out red when there is wide spectrum white noise, and it does not vary according to setting of the audio level control I imagine it's some visual indication of the audio signal to noise ratio on the input to the audio chain in the presence of a signal? Just a guess though.
Hopefully Simon will illuminate us if he happens to read this post!
