Server Connections
Posted: Sun Feb 07, 2021 3:07 am
by VK7OO
I have a server with one radio & one account. It is setup to allow only LAN connections & works well.
However, I can only make one connection to the radio. Another client cannot connect because the radio is "in use".
Is this normal? I had hoped I could connect multiple clients to the same radio.
regards
Steve VK7OO
Re: Server Connections
Posted: Sun Feb 07, 2021 7:54 am
by VK5MCA
Hi Steve
Check in the Server Manager app, by default the number of connections for WAN is set to 1. You can increase it to a max of 10.
Posted: Sun Feb 07, 2021 12:19 pm
by KA1GJU
Steve,
One physical user per radio ONLY. It's not usable like Kiwi's or the WebSDR's where numerous users can access one physical radio.
You can place more than one SDR on the same physical server, by adding more SDR's via the Radios tab of the Server Manager.
Callum's response is limiting how many connections on the server per the user's public IP address. For example, my Super Station #4 happens to have 4 SDR's of various MFG's. I have set Max connection to 2, this will allow users to operate two physical SDR's simultaneously for comparison. It also keeps the server hogs from occupying all the SDR's on the server while they monitor vast sections of spectrum.
So, with that in mind... the answer is no. One user per one SDR at a time only.
Home of the Super Station Servers
Posted: Tue Feb 09, 2021 2:02 am
by VK7OO
OK
Thanks Chris
Yes I had the right idea about WAN connections
De VK7OO
Steve
Posted: Tue Mar 22, 2022 11:46 am
by hb9ryz
Hallo All
The original Perseus Software will allow multiple connections from more than one client at the same time (concurrent).
I don’t know, if Simon could fix this in order that two remote clients running SDR Radio Console are able to connect the same SDR attached to the SDR Radio Server.
Best 73’ de HB9RYZ
Wolfgang
