Page 2 of 2
Re: Another freeze-up
Posted: Thu Sep 24, 2020 11:16 pm
by mbott
To give credit where credit is due. Replaced the desktop power supply today. The RSPduo has been running like a top ever since. I did remove the previous test kit and the Registry entries, then installed today's test kit.
Thanks Simon.
Posted: Fri Oct 02, 2020 6:13 pm
by mbott
Eight days later and it freezes up again. This is the opportunity to build a new system and convert the existing system to Linux. Going shopping next week. I foresee a i7 10th gen system in my future.
Posted: Fri Oct 02, 2020 6:39 pm
mbott wrote: ↑Fri Oct 02, 2020 6:13 pm
Buy a good USB3 PCIe card. Don't buy 10th gen, wait for 11th gen later this year.
Posted: Fri Oct 02, 2020 7:51 pm
by mbott
The *only* slot I have available is slot 4. My GeForce GTX1050 occupies slots 1&2 with my wifi card in 3.
Posted: Sun Oct 04, 2020 11:34 pm
by G6PZZ
I mentioned this card earlier. Here it is:
Cost is £26 It should fit in the reaming slot okay. You'll need a spare SATA power lead. If building from scratch, I recommend a full size ATX board. Slightly bigger case needed. Mine's a Gigabyte Z490 UD. There's another version that has two antenna sockets on the backplane which may be of interest to you.
HTH
Tom G6PZZ
Posted: Sun Oct 04, 2020 11:40 pm
by G6PZZ
Can't post the URL for some reason.
Drop me a line to
tom@crosbieit.co.uk if interested.
Posted: Tue Sep 14, 2021 11:34 pm
by mbott
Since this happened, I've been running a controlled experiment. This issue continues, however it only occurs with the SDRplay RSPduo. I have an RSPpro and the issue never happens with it. I've moved the RSPduo between two different i7 systems (one a desktop and one al gamers aptop), and it's only occurs with the RSPduo. The USB cable in use makes no difference.
Posted: Wed Sep 15, 2021 6:17 am
mbott wrote: ↑Tue Sep 14, 2021 11:34 pm
It's the port, not the cable. Also check the USB power settings.
